fiberglass
Aug 10, 2007 | 11:43 PM
fiberglass
Has anyone experimented with making there own fiberglass enclosure?
Aug 11, 2007 | 12:16 AM
St. Jude Donor '08
there are a few floating around here. Check the "what do you run in your system" thread
off the top of my head, GB vette has one of the coolest enclosures/ampracks i've ever seen
Kale is a fiberglass-a-holic
and a few others whose SN's i can't remember (flame suit on)
Aug 11, 2007 | 08:40 AM
St. Jude Donor '08-'09
quite a few have... I stick with wood, its easier for me but not a nice looking at fiberglass of course
One of these days ill get adventurous and learn fiberglassing
Aug 12, 2007 | 12:26 PM
St. Jude Donor '08
yes, but it's a crap load of work
Aug 12, 2007 | 01:03 PM
St. Jude Donor '06
it is a lot of work. but you can get pretty creative with it to get that unique look.
Aug 12, 2007 | 01:15 PM
Very time consuming. Anything you want to know in particular?
oh yeah and, a cheap mask won't help you. You need a full on chemical respirator if you plan on working with this stuff.
Aug 13, 2007 | 08:08 PM
Your best bet is to use wood where you can and glass where you need
Aug 14, 2007 | 02:21 AM
Aug 14, 2007 | 10:20 AM
Quote:
Originally Posted by
St0rm
Aug 14, 2007 | 03:21 PM
That was a test fit, which is why the wires were everywhere. This is currently under construction, i will clean up the wires after i get everything mounted in, no use doing it before.
Aug 17, 2007 | 08:20 PM
jthom
OOOO Ya
This is my first one......It's up side down....
This is a link to the build of my car there is some good info in there from many members who helped along the way.......Hope this helps..
http://forums.corvetteforum.com/show...=keith+podolan
Aug 18, 2007 | 03:37 AM
Aug 18, 2007 | 10:39 AM
Aug 18, 2007 | 11:28 AM
And get use to smelling it for awhile...outside and inside the car
Aug 18, 2007 | 11:43 AM
jarda
Weird.... Mine never stinks once its dry... after a few hours even. Are you sure you're using enough hardener?
Aug 21, 2007 | 04:29 PM
ttt
ttt
Aug 21, 2007 | 05:15 PM
jthom
ttt
What more do you want?
Do you have a specific question??
Aug 21, 2007 | 07:20 PM
