Sponsored by: Innova
Delco Bose problem in 82 Crossfire
Old Nov 6, 2001 | 02:00 AM
82Jaws's Avatar
82Jaws
Cruising
Default Delco Bose problem in 82 Crossfire
1982 Crossfire, 30,000 miles with original Delco Bose radio with Cassette. Unit was working fine until one day last summer when radio stopped working. cassette works fine, sound is good. Digital displays fine. Radio reception and display did return for short while but stopped and havent been bach since. Unit works fince except for this. Fuses Good.
Any suggestions as to problem, where to look and how to fix would be appreciated. Thanks :rolleyes:
Old Nov 6, 2001 | 02:09 PM
92TripleBlack's Avatar
92TripleBlack
Default Re: Delco Bose problem in 82 Crossfire (82Jaws)
Are you getting nothing, static, etc. when you turn on the radio. Does it look like it should be working?
92TripleBlack
Old Nov 7, 2001 | 12:55 AM
82Jaws's Avatar
82Jaws
Cruising
I am not getting any sound or noise of any type. The display shows the time. No radio stations are illuminated. cassette and speakers work fine. Any suggestions? Thanks
Old Nov 7, 2001 | 01:25 AM
1988L98's Avatar
1988L98
Hi
You have a switch in the cassette housing that goes bad some times, when the cass is in, the switch is up, when the cassette is out, the switch suppost to go down, the switch mute the radio so you can hear the cassette, hope you understand what i am saying, we work this problem all the time.
Hope this help you.
Al
Old Nov 8, 2001 | 08:40 AM
82Jaws's Avatar
82Jaws
Cruising
Thanks for the info. It makes sense. Is switch this something I can fix or do I need to have someone work on the unit? Does the unit need to be removed and disassembled? Any estimate on cost? Thanks for your help on this.
To Delco Bose problem in 82 Crossfire
