Sponsored by: Innova
My Humble Sub Install (C5)
Old Aug 20, 2007 | 11:02 PM
FinishLine's Avatar
FinishLine
Default My Humble Sub Install (C5)
First of all, I would like to thank all the members in this forum for all the tips and ideas for my install. It was really helpful. Little things like liquid nails, where to ground the amp, gromet under the battery etc were all invaluable.
I'm not in to competition as you can see from my system. I just wanted to add a little extra bass and to keep everything as stock looking as possible. With the exception of the Subthump, I did everything on my own, again with help and research from this forum. I am quite happy with how it sounds and I have the satisfaction of doing it myself.
System:
Stock Bose HU, amp & speakers.
PAC OEM-Vet1 4 channel line output adapter ($40 eBay)
PAC Auxbox iPod adapter ($32 eBay)
Subthump 10" stealth box ($120)
Punch 10" P1 sub ($50)
Alpine 3536 amp (I had this kicking around)
The amp is six channel bridgeable down to 3 and it's overkill but I had it sitting around doing nothing so it was time to put it to use.
Other misc items:
2 16 ft rockford RCA cables ($10 each)
16 ft power cable (4 gauge) ($20)
16 ft trigger wire ($3)
10 ft ground cable (8 gauge) ($12)
4 ft speaker wire (12 gauge - for the sub) (I had this)
MDF for mounting the amp ($3.75 in the shelving section at Home Depot, including the cut to size)
Installation is well documented so I won't go in to that. Just a few things that I did not see anyone mention...
1) I had to move the stock CD changer to the right compartment. No issue. It actually works out well with the Auxbox as I connected that to the changer cable in the same compartment. If I ever want to connect the changer, everything is right there.
2) The stock mounting screws for the changer had to be cut. I had no way of getting them out and the subthump wouldn't fit with them in there.
3) It's a real pain to find 10 feet of 8 gauge ground cable. Most stores sell 3 feet. I had to ask an install shop to sell me the cable by the foot.
4) Its better to cut the foam off the back panel if you mount some MDF back there to secure your amp.
Here are the pics:
I didn't want the iPod showing so I ran the wire under the carpet from the back right storage bin, under the center console and in to the area under the arm rest. I have enough cable left over to move easily hold and select my playlists etc.
This is everything all buttoned up.
This is without the cover.
And the Sub.
Old Aug 20, 2007 | 11:31 PM
monstrocity's Avatar
monstrocity
I dig it man. Like the minimalist look and the way the iPod is hidden! Bet it sounds sweet.
My 92 coupe has a factory tape deck. Sounds remarkably bad. My 96 Roadmaster "Concert Sound II" stereo sounds however remarkably awesome! The disparity makes me wonder sometimes.
Old Aug 20, 2007 | 11:49 PM
scott_fx's Avatar
scott_fx
looks great man. if i had one suggestion it would be to make a facade for your 'amp rack'. having it look 'flush mounted' as well as hiding the wires. regardless, if you leave it the way it is or not, looks good man.
Old Aug 21, 2007 | 12:42 AM
FinishLine's Avatar
FinishLine
There are options for a C4...you should check in to it.
Old Aug 21, 2007 | 12:43 AM
FinishLine's Avatar
FinishLine
Thanks for the tip...I was thinking of getting some black plastic conduit to hide some of the wires.
Old Aug 21, 2007 | 01:05 AM
Brabus2's Avatar
Brabus2
Very nice job!
To My Humble Sub Install (C5)
