Sponsored by: Innova
C5 > How much noise?
Old Aug 22, 2007 | 11:53 AM
Spkrboy's Avatar
Spkrboy
I see only three possibilities left...
1-The amp and deck impedances don't play nice
2-The Alpine has a noise issue (try an outboard AC>DC converter to power the Alpine and test then to verify) but it's unlikely
3-You never noticed it before (for any of a few different reasons)
Old Aug 22, 2007 | 12:02 PM
Kale's Avatar
Kale
1 - Maybe, kinda strange for two piece of equipment from the same brand. I'll hook up my old ARC amp to it tonight and see if it hisses.
2 - I did try headphones on it, with no noise, but... it's not designed to drive headphones, so...
3 - 0-bit noise check used to be part of what I did in an install, in the last 2 cars this was in. It was grave silent up to about 32/35.
Old Aug 22, 2007 | 12:10 PM
Spkrboy's Avatar
Spkrboy
Last shot... use the same 0-bits track from another HU to drive the amp.
You've been through so many other system mods in the past couple weeks, I hesitate to say that it might even be related to that crossover issue we discussed, if that's still set up that way. That's a very remote possibility, but...
Old Aug 22, 2007 | 12:22 PM
Kale's Avatar
Kale
I'm actually active now from the 9855.
Those crossovers are gone.
jbondfl's Avatar
jbondfl
From: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
Hard to follow along here but is it hissing with a commercially produced CD? Maybe the problem is with the music you are putting on the cd or ipod from your PC???? Does it hiss using the tuner?
Old Aug 22, 2007 | 12:26 PM
Kale's Avatar
Kale
nah we already determined it hisses on a cd track that is silent.
Old Aug 22, 2007 | 12:27 PM
robvuk's Avatar
robvuk
Are you sure you don't just have your inputs set much higher than necessary on the amp? That's why I asked what the maximum numerical setting was on the HU. The mere fact that the hiss goes away when you put it in pause clearly rules out everything but gain structure, the HU or a noisy CD itself. I haven't seen an impedance mismatch in modern day equipment since the 70's. So I'm sure that's not the problem.
Old Aug 22, 2007 | 12:33 PM
Kale's Avatar
Kale
well, if I put the gains to 0, I still get hissing, just quieter hissing.
Old Aug 22, 2007 | 12:41 PM
robvuk's Avatar
robvuk
Then you have an electronic problem with the HU. But I still don't know what the max level is.
Old Aug 22, 2007 | 12:47 PM
Spkrboy's Avatar
Spkrboy
There were impedance issues all over the place in the early nineties when guys were using 8-16v AudioControl and Rockford low-output-Z preamp components to over-drive amps that were designed for 500 mv. Not much anymore, agreed, but it still pops up from time to time.
My vote is for the HU. There's most definitely a mute circuit in there (and has been for a long long time), so you have to run the 0-bits track. I'd hook up a different HU and see what happens before assuming the hiss is abnormal.
Old Aug 22, 2007 | 12:51 PM
Kale's Avatar
Kale
The pioneer 7800, same car, samp amp, hisses too, but only slightly, and the same amount of hiss all through the volume range until the last few ticks of the dial.
It MUSt be the head unit, strange it started when I put it in this car , though.
How do I make the HU stop hissing?
Max volume on HU is 35.
Old Aug 22, 2007 | 04:11 PM
robvuk's Avatar
robvuk
See post #5.
I know you don't want to but just for fun, try lowering the input level on the amps just a bit. You'd be surprised how much a tiny bit of input level can reduce hiss. It sounds like you've got plenty left over on your HU to make up for it.
Old Aug 22, 2007 | 04:31 PM
  #33
Kale's Avatar
Kale
Like I said, I tried it with the gains all the way down. clocked to 0, the noise is still present.
Old Aug 22, 2007 | 04:35 PM
  #34
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
If you have an Ipod or other MP3 player, get a 1/8"audio/RCA connector from radioshack. Plug your MP3 player into the amps RCA jack. If the noise remains, It's your amp, if it goes away it's either your headunit or a poor connection with the RCA cables.
Btw, what RCA cables are you using?
Old Aug 22, 2007 | 04:43 PM
  #35
robvuk's Avatar
robvuk
Are you talking about the gains on the amps or the HU? If you turned the input levels on the amps all the way down and it still hisses then you've changed your story and therefore the problem lies in the power amps.
Old Aug 22, 2007 | 05:20 PM
  #36
Spkrboy's Avatar
Spkrboy
As we discussed above, RCA cables can't cause this issue, and the iPod is not meant to drive amplifiers directly without special considerations, so directly connecting an iPod solves nothing. Forget the iPod.
If you really want to dig into this, then swap the amp, then try powering the HU from an outboard source, then try a different HU altogether (which it sounds like you did with the Pioneer, but to be meaningful, everything else had to remain the same).
Old Aug 22, 2007 | 05:30 PM
  #37
Kale's Avatar
Kale
#6, #11, #20, #28, I mentioned that I tried it with the gains all the way down.
When I say "gains" I'm talking about the gains on the amplifier.
When I say "volume" I refer to the volume setting of the head unit. I'm not using them interchangibly.
when I get home, I'm going to unplug everything bit by bit too. Ipod adapter, antenna, then if it still exists, I'll run rcas to an amp in another car that's already set up for this head unit.
I seem to remember reading somewhere, maybe some years ago, about someone getting hiss from his antenna.
To C5 > How much noise?
Old Aug 22, 2007 | 07:15 PM
  #38
robvuk's Avatar
robvuk
Ok, sorry. I guess your amp does not have an input level control (gain control) that goes to 0 or off. It apparently only attenuates by a certain number of db. Otherwise when you turn it all the way down it would be quiet. So this is where the confusion comes from. I don't think you ever mentioned that or what kind of amp it was. These are the kinds of things that makes it difficult to diagnose something from a distance. That's why you get a lot of seemingly dumb questions.
I assume then that you are still able to play music with your "gains" turned all the way down but the noise is still unacceptable? If that's the case, your HU is definitely abnormally noisy.
Old Aug 22, 2007 | 07:24 PM
  #39
Spkrboy's Avatar
Spkrboy
OK, gents, the frustration level is creeping up, so let's breathe.
That's radiated noise, and usually from an old antenna FM booster module. Nasty things those were. No way that's the problem here.
I gotta agree whole-heartedly there.
If you're running lines between vehicles, try the reverse while you're at it just to see what happens.
Old Aug 22, 2007 | 10:51 PM
  #40
Kale's Avatar
Kale
sorry, they are PDX amps. Never had an amp with a gain switch, thought that was just marine stuff.
Anyway,
Removed ipod connector, unplugged fm antenna, still get static. OK.
Connected RCAs to the amp in my other car - I still get the hiss.
the HU came from this car, so that amp is only there because I'm too lazy to pull it.
So, 100% for sure its the head unit, in this car. Strange, that it started so suddenly. I wonder if I did something to it when I put it in the car.
