Sponsored by: Innova
C5 > How much noise?
Old Aug 23, 2007 | 12:05 AM
  #41
robvuk's Avatar
robvuk
Originally Posted by Kale
sorry, they are PDX amps. Never had an amp with a gain switch, thought that was just marine stuff.
Anyway,
Removed ipod connector, unplugged fm antenna, still get static. OK.
Connected RCAs to the amp in my other car - I still get the hiss.
the HU came from this car, so that amp is only there because I'm too lazy to pull it.
So, 100% for sure its the head unit, in this car. Strange, that it started so suddenly. I wonder if I did something to it when I put it in the car.
I looked up that amp. Try as I might, I couldn't find any technical information on it. It sounds like you have some kind of switch for selecting input sensitivity ranges. I assume you've played around with that?
Old Aug 23, 2007 | 01:46 AM
  #42
Kale's Avatar
Kale
The 4.150 doesn't. The mono versions of the PDX do, though.
Old Aug 23, 2007 | 09:50 AM
  #43
DPG's Avatar
DPG
St. Jude Donor '06
Anyway,
Kale
When Greg and I installed a pdx amp in a c6 a few weeks ago, it had a bad power block straight from the factory. If you move the power terminals it would cut in and out. Maybe something similar is going on with yours. But as these guys are starting to narrow it down, it does seem to be a HU. But having that experience with that amp straight out of the box, I would be leary of the pdx
