Sponsored by: Innova
Help Please!!
Old Aug 25, 2007 | 06:06 PM
Mister Peebody's Avatar
Mister Peebody
From: Ok! So you don't believe in conspiracies, but will you acknowledge the possibility of there being coordinated activities in secret places? Texas
Default Help Please!!
Which fuse supplies power to the 12V constant in the footwell? And is said fuse in car or under hood? I had power, but now I don't. Please Help?
Thank You!
Old Aug 25, 2007 | 07:35 PM
Buddy A's Avatar
Buddy A
On a C6 you can use the heated seat fuse with the add-a-circuit. Under the footwell of the passenger side.
Old Aug 26, 2007 | 01:12 AM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
there are several. i simply tapped into the battery + terminal post on the underhood fuse box. IMO it's the cleanest way to get a constant source and you don't risk blowing a fuse or robbing an accessory of power.
Old Aug 26, 2007 | 02:18 AM
Vette-kid's Avatar
Vette-kid
What are you running power to? Is there anything wrong with tapping into the supply for the fuse box in the pass footwell?
Old Aug 26, 2007 | 02:58 PM
Mister Peebody
My question is in regard to the orange, yellow, and black wires in the passenger side footwell that are not used from the factory. The yellow is the commonly used acc. power supply. The orange is a constant 12 volt supply that I used to power the Nav module and brain for my headunit. I've lost power to it and need to know which fuse is associated with it.
Old Aug 30, 2007 | 04:35 PM
Mister Peebody
Default For Future Reference
Thanks to Mr. Bill Curlee, I can post this information for future reference:
The yellow wire is fused at the instrument panel fuse panel with fuse# 11 (assry/off) 20 amps
The orange wire is fused at the instrument panel fuse panel with fuse# 7 (c/ltr) 20 amps
Black is ground
This info was specifically solicited for a 1998 C5 convertible, but it may be accurate for other/all C5s.
Thank you again Bill.
Old Aug 30, 2007 | 04:38 PM
DPG's Avatar
DPG
St. Jude Donor '06
should add it to the faq. Bill is the greatest
Old Aug 31, 2007 | 07:05 PM
Mister Peebody
Done!!
I didn't realize that stickies could be posted to. I thought they were locked, but now I know!
To Help Please!!
