Sponsored by: Innova
95 Audio Help
Old Sep 18, 2007 | 09:58 PM
DG'sVette's Avatar
DG'sVette
Default 95 Audio Help
I believe my rear speakers are shot. I think I want to just replace everything.
Will the wiring be fine if i just replace the Head Unit & the speakers or will I need to do something special with the wiring because of the BOSE?
Old Sep 20, 2007 | 02:26 AM
bogus's Avatar
bogus
did you read the C4 Audio FAQ?
Old Sep 20, 2007 | 06:41 PM
DG'sVette's Avatar
DG'sVette
Default Wiring Question
I did read over the FAQ's. I understand I cannot run non Bose speakers with my current head unit / amp.
I'm thinking about replacing the head unit & speakers with something after market.
I just don't understand if I have to replace all of the wire or just eliminate the BOSE AMPS. I'm not sure if there is a separate BOSE AMP for each speaker or if there is just one amp behind the driver’s seat. I'm lazy & haven't taken the time to look yet.
This weekend will be the beginning of the project. My first attempt will be just looking things over to gauge the depth of the project. The second thing that I will address is to figure out if I just want to replace everything or try to fix what may be broken.
I appreciate the help.
To 95 Audio Help
