Sponsored by: Innova
Questions
Old Sep 19, 2007 | 09:16 PM
Mister Peebody's Avatar
Mister Peebody
From: Ok! So you don't believe in conspiracies, but will you acknowledge the possibility of there being coordinated activities in secret places? Texas
Default Questions
I have a Kenwood KVT-819DVD and a Alpine PDX 1.600 on a JL 10W6v2 in a sealed stealth enclosure.
What does the "loudness" button on my Kenwood headunit do? Obviously it makes things loud, but what does it actually do to the signal?
My stereo sounds much better at low volume with the loudness on.
Also I read on this forum that having gains on amps turned all the way up is bad, why?
Old Sep 19, 2007 | 09:56 PM
Spkrboy's Avatar
Spkrboy
Loudness (as well as Alpine's BBE) is an EQ curve that increases bass and treble at low volumes, but the amount of boost gradually diminishes as the volume is turned up. Where and how the boost is done is different from manufacturer to manufacturer.
Running amps at high gain is NOT inherently a bad thing unless your system has a noise issue. Lowering the amplifier gain control allows a higher voltage signal from the upstream components, allowing for potentially more noise-free signal once it gets to the amp. If you have a suitable noise floor, the amplifier gain is actually irrelevant.
Old Sep 19, 2007 | 11:18 PM
robvuk's Avatar
robvuk
Loudness Compensation is the complete term. The human ear doesn't hear bass and treble at low volumes as easily as it does at high volume. It is intended to make it sound better at low volumes, just as you described. Some of the cheaper units do not decrease the boost at higher outputs, they just expect you to turn it on when low and off when high.
Spkrboy covered the other point very well.
Old Sep 20, 2007 | 02:18 AM
Mister Peebody
Yes he did! Helpful as usual, as were you.
Thanks Guys.
To Questions
