Sponsored by: Innova
tuning amps
Old Sep 22, 2007 | 10:56 PM
03redzo6's Avatar
03redzo6
Default tuning amps
alright guys finally got around to installing the system, but know it sounds like crap. i really don't know how to tune the amps. can someone give me some advice on this, and ill try to get some pics in the morning. thanks, albert.
Old Sep 22, 2007 | 11:11 PM
VinceC5's Avatar
VinceC5
here's a good start on how to adjust the input gains.
http://mobile.jlaudio.com/support_pages.php?page_id=143
Old Sep 22, 2007 | 11:28 PM
Kale's Avatar
Kale
Define 'sounds like crap'
Old Sep 22, 2007 | 11:56 PM
03redzo6's Avatar
03redzo6
it sounds dull and plain, its not clean crisp sound
Old Sep 23, 2007 | 12:00 AM
Kale's Avatar
Kale
Switch the wires on one of your tweeters. (reverse + and -)
it would also help if you told us what you had, and where it is installed.
Old Sep 23, 2007 | 12:18 AM
03redzo6's Avatar
03redzo6
Pioneer deh-p7900bt deck
Infinity kappa 60.7cs components in front
Infinity Kappa 52.7i 2-way in rear
4-channel Infinity Reference 475a amp powering front and rear speakers
Infinity Kappa 104.7w subwoofer
Mono Infinity Reference 1300a amp
Old Sep 23, 2007 | 02:04 AM
Kale's Avatar
Kale
Ah well... just try different tweeter placements... that particular set isn't known for being dynamic.
Old Sep 23, 2007 | 10:02 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
That is an awesome link, but what if you have no idea what 3/4 volume is? Like the stock radio. It turns and turns. How can you tell what 3/4 volume is on a radio that does not tell you.
Old Sep 23, 2007 | 11:08 AM
Kale's Avatar
Kale
You can always turnt he gains all the way down on the amp
turn the head unit up until you hear distortion, turn it down slightly, then set the gains from that point.
Old Sep 23, 2007 | 03:00 PM
screw991le's Avatar
screw991le
Old Sep 30, 2007 | 09:54 AM
ptiller's Avatar
ptiller
Where is you current tweeter location for the fronts?
If you mounted the tweeter and woofer using a baffle plate in the door where the orginal BOSE were , it is possible that the tweeter is actually covered up by the door trim ( if the tweeter is mounted high up on the plate. That would make it sound dull and flat. The tweeter needs to be mounted low on the baffle plate near the woofer OR mount the tweeter elsewere. There are many post on tweeter mounting elsewhere one the door or dash/pillar area.
Good Luck.
To tuning amps
