Sponsored by: Innova
Adding Sub to Bose
Old Sep 28, 2007 | 12:20 PM
z28rktec's Avatar
z28rktec
Default Adding Sub to Bose
I know I can use the PAC OEM-Vet1, but my amp also has speaker level inputs. Is there anywhere on the bose that I can tap into to get a good signal or should I go with the PAC unit. This is for an '02 c5.
Thanks!
Old Sep 28, 2007 | 12:51 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
You can tap the speaker for the line level input. But it will sound like crap. Spend the extra time and money on the PAC. IMHO.
Old Sep 29, 2007 | 01:26 AM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
you must go inside the doors and tap at the bose sub, the rear speakers dont provide a full frequency output, they are highpassed from the radio
Old Sep 29, 2007 | 03:41 PM
z28rktec's Avatar
z28rktec
Sounds like the PAC is the way to go. I called some local shops and they have similar units but require spicing in the wires. The plug and play sounds good.
To Adding Sub to Bose
