Sponsored by: Innova
Uncontrolled Sub
Old Sep 26, 2007 | 10:28 AM
Mister Peebody's Avatar
Mister Peebody
From: Ok! So you don't believe in conspiracies, but will you acknowledge the possibility of there being coordinated activities in secret places? Texas
Default Uncontrolled Sub
I've got a JL10W6v2 in a stealth box, powered by a PDX 1.600. The sub-sonic filter is set to 15hz the x-over is set at 80hz on the amp.
My issue is that the sub seems to move almost to the point of uncontrollably. It sounds loud and clear in the passenger compartment with the trunk closed, but if the trunk is opened and the center compartment cover is off it doesn't sound clean. It moves only when it should, but it looks like it's moving too much. It doesn't move during the silence between tracks or if the volume is down.
What might the problem be?
Thanks in advance!
Old Sep 26, 2007 | 10:46 AM
Kale's Avatar
Kale
Originally Posted by Mister Peebody
I've got a JL10W6v2 in a NVTHIS stealth box, powered by a PDX 1.600. The sub-sonic filter is set to 15hz the x-over is set at 80hz on the amp.
Thanks in advance!
A lot of subs sound like crap at high volumes when you have a vehicle open. Just turn it down until it sounds good. Remember, opening the door is changing its enclosure.
Old Sep 26, 2007 | 12:18 PM
NVTHIS's Avatar
NVTHIS
From: Piedmont, SC Currently Own: 99 Nassau blue FRC. Previously Owned: 84,95,98 Indy Pace,01 Z06
Very true! I remembering opening the deck lid on my Z06 and hearing the sub honestly didn't sound as good, but up in front in the drivers seat, it hit Loud and Clear. I think alot of it has to do with the environment like Kale said. Hopefully that's all it is. Let me know what you come up with.
-Jason
Old Sep 26, 2007 | 12:24 PM
Spkrboy's Avatar
Spkrboy
I'd assume the box was designed with that driver in mind? If not, it could be the wrong combination. A box built too large can allow a driver to easily unload at very low frequencies whether you have a subsonic filter working or not.
Old Sep 26, 2007 | 06:50 PM
Mister Peebody
FYI - I posted the box maker only for box type/ construction reference, in other words to let you know that it was a well built box. I am a happy customer, for the record.
It sounds good at any volume in the passenger compartment. It's only when I pop the trunk and stand over it to look in at it.
I guess the only thing that matters is that it sounds good where I sit and anywhere within earshot of the car.
Thank you!
Old Sep 26, 2007 | 11:51 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
I had similar problems when I first installed my Jl12w6v2. I adjusted this by installing a remote gain control ****, adjusting my settings and bumping up the gains on my full range speakers.
According to the JL website, your subs ideal power handling, is about 400watts. A 600 watt amp is pushing enough to drive two of these subs. Perhaps you should turn down the gains or consider a smaller amp. A JL A1400 series amp should fit power needs.
Old Sep 27, 2007 | 02:15 AM
Shangreer's Avatar
Shangreer
While 600 Watts is pushing the safety zone for that sub, it should be OK. If it sounds good in the passenger compartment then I'd close the trunk and be happy. How often are you really going to be sitting in the trunk?
Old Sep 27, 2007 | 03:03 AM
scott_fx's Avatar
scott_fx
I'm with spkrboy on this one, just because you can't hear it when the trunk is closed, doesn't mean it's not going crazy. I'd double check the internal volume of the box, the specs on the sub and then if they are off then adjust the box volume accordingly (add some blocks of wood to take up some space if needed)
Old Sep 27, 2007 | 08:06 AM
Spkrboy's Avatar
Spkrboy
As long as your box is somewhere between 0.5 and 1.0 ft^3, you should be fine. To be more precise, a box of about 0.75 with a bit less than a pound of polyfill should be best. This driver should NOT be in a vented enclosure, no matter what JL says on its site. If your box meets these requirements, you're probably just seeing typical high-xmax driver behavior, and there's nothing wrong.
Old Sep 27, 2007 | 01:47 PM
Mister Peebody
Thank you all for the help. The box is not vented and I don't believe it has fill in it (I bought it loaded). I'll contact the supporting vendor that built my box to get internal spec info. On second thought, maybe he'll chime in here?
Thank you again.
Old Sep 27, 2007 | 01:50 PM
Kale's Avatar
Kale
even when i undersized enclosures, subs sounded like **** with the vehicle open, at high volumes. <shrug>
Old Sep 27, 2007 | 01:59 PM
NVTHIS's Avatar
NVTHIS
Hey Damon, that box has an internal volume of around 0.78-0.83 cu ft. That box did not have polyfill in it because I didn't think the sub needed to act like it was in a bigger enclosure as that is what polyfill usually does. It may need a little in it for damping factors but not for volume sake. Let me know if you need any other info, Damon!
Old Sep 27, 2007 | 03:00 PM
scott_fx's Avatar
scott_fx
hmm, i didnt have that problem with my last sub. actually sounded better with the top down
Old Sep 28, 2007 | 12:09 AM
Mister Peebody
Thanks for the info!
It sounds great with the top down. I popped the trunk and removed the center cover to show someone the subwoofer while it was playing and only then did I have the previously stated issue. That's the only time! Under any other condition it's great.
I think I'll just take Shangreer's advice and stay out of the trunk.
Old Sep 28, 2007 | 12:32 AM
Kale's Avatar
Kale
hmnnn trunk lid = loading board
Old Sep 29, 2007 | 10:04 PM
Mister Peebody
I guess so!
Thanks again Guys.
To Uncontrolled Sub
