Electrical Gurus, Need help with a strange Ammeter
http://forums.corvetteforum.com/show....php?t=1809697
I'm installing a replacement ammeter because the cool one I have is broken. The replacement is this model:
http://cgi.ebay.com/1-0-Digital-ANL-...QQcmdZViewItem
Before I went cutting and drilling, I decided to test the unit. Here's what's weird. When wired in-line between the Alternator and Battery (as shown in pic) It works fine.
However, when wired between the Battery and Sound system main power wire, the Amperage reads Zero. The voltmeter part works in both setups but either there's something strange up, or I have the the worlds most efficient sound system.
What am I doing wrong?
If you're getting less than that, you probably just THINK that's the main sound system wire.
I've decided to try a deticated digital ammeter that uses a remote shunt and has a much more accurate processor. The seller has assured me this unit will work on automotive 12v systems and the electronics look alot more sturdy than the one I have now.
http://cgi.ebay.com/ws/eBayISAPI.dll...m=190159172490
The fun part will be fabricating a plexiglas mounting surface since the hole I cut for the original one is larger than the new one. I have cool plans in store for it though.
I'm no "expert" but I know a little bit. Maybe I can help explain what is happening.
When your vehicle is running, there is a high demand for current from your alternator. All of the devices that require power (ignition system, radio, computer, sensors, etc...) are getting their required power from your alternator. Your battery is also another device that is receiving power from your alternator when your engine is running.
Basically, all of the current being delivered to your vehicle is being supplied by the alternator when your engine is running. Things are turning on/off, but the average load is there... simple enough, right?
Every device has a threshold of sensitivity. Some current sensing devices detect the changes in magnetic energy and relate it back as current flow. Others measure current by looking at the voltage drop across a known component... like a solid piece of brass for example. This is known as a shunt. Add a voltage meter across the brass, and you can now determine the current flow in that piece.
Another thing to consider is the reaction time of the metering device. Some simply cannot keep up with the changes in current flow... so they don't read correctly. Some are so sensitive, they need snubbing circuits to 'average' the input signal so you can get a good reading.
In your case, I think your overall load is so small/fast that it is below the sensitivity threshold of your ammeter. (DC to DC switching power supplies and low overall 'full current' duration.)
If you want, keep it connected to your system and connect a load back at your amplifiers. (Maybe a 12 vdc air compressor, or some fog lights, etc...) You should see that ammeter pick up with enough average load.
Let me know if this helps, or if you need me to clarify anything.
Mark
) Install on this guy will be in a few weeks.
