Lock windows in a fixed position.
Recover seats in cloth.
Recover pretty much entire interior with thin foam backed cloth (Think headliner.)
Liquid damping on outside of all panels, mat damping on inside in conjuction with LuxuryLiner
Head unit? Undecided... Maybe F1.
Dynaudio 10" midbasses up to 1khz in sealed door enclosures
Molded dynaudio MD142 midranges in the doors, in a lower area. 1khz-5khz
dynaudio MD102 tweeters, 5khz+, molded into a-pillars much like mine are now.
Subwoofers in rear corners, running in stereo. Probably ARC 10s.
ARC amps, maybe Foose line.
Power (each):
Midbass - 350w
Midrange - 90w
Tweets - 90w
Sub - 200w
On second thought, I'd try the new Focal Utopia Be tweeters.
Power (each):
Midbass - 350w
Midrange - 90w
Tweets - 90w
Sub - 200w
Recovering the seats and other surfaces in Cloth may not be a bad idea. Are there other materials that would have the same acoustic qualities?
Supposedly it uses an advanced noise cancellation technique. I'd love to test it but the PXI-H990 is quite expensive for a sound processor at ~$2000 when last I checked.
If you're doing the entire interior 1lb/sqft does add up...but not any more than riding with an average sized passenger. It's not like you're coating your car with liquid lead.
I think my car gained 50lbs with the addition of the dynamat and probably another 100 with the sub/box and Amp rack. It just so happens that the majority of this weight is over the rear wheels which gives me better traction on questionable road conditions.
if I was going to add ~1000 extra lbs between equipment and sound deadener, I probably wouldnt use a vette to start with. maybe an xlr since its much quieter to start with.
Well, for a great system, the Vette is a horrible place to start. It's all ...mitigation.
Here is a rundown of the weight of my new system so far. I was wondering what it would weight knowing the C-5 has a 399 lb cpacity. Weights were taken just prior to install weighed on a scale.
57 lbs Dynamat 36sq feet X3 - throughout, doors iner and outer
