NAV acting wierd today!
So I am heading down the road and noticed I couldnt get my NAV to work on my Kenwood ddx6019 with KNA G510 NAv add on.
This had me puzzled and pissed!! I tried to check setting and everything seemed to look fine. I then wondered if I lost some of my settings for some reason with the battery getting low. Just so happened that DPG was meeting up with us today and I asked him what he thought. HE wasnt sure either. SO when I got home I disconnected the battery for a minute or so like we both talked about and hooked it back up and my NAV is now working. I dont know if this was the issue, but it solved my problem(hopefully).
Does this make sense to all you audio experts out there that i could of had a problem with the battery going dead?
I dont know but I thought I would share this in case someone else has had a similar problem and you can try what happened to me.
PLease give me some thoughts on why you think this happened.
I did check the connections to the GPS unit and they were fine so it wasnt because they were loose either.
