Component/Amp time...help me out... ???
(pics of my current sub set up and possible new Amp...below)
I was thinking about using this amp?????
Current sub
D-3
If you're running just front channels, that amp will put out plenty of power. If cost is a factor, You may want to look at the MRP F450 (down one size from the one you pictured.) you can pisk one of these up from ebay for under $200. In bridged mode, this amp will give you 200watts of power @ 4 ohms. plenty of power for your mids.
I'm using Alpine's SPX-177r components. The newer model SPX-17REF are out now and have a different style tweeter than the older model. These coupled with the Alpine MRP F450 should give you excellent sound for $384.
You'll have to fork out about $30-50 more for terminals, wires and MDF or other material to re-build your door speaker plate.
harsh spitty tweeters will be harsh at 0, and still harsh at -3.
Alpine SPR-17s 6.5
General Specs:
• Sensitivity: 87dB / W(1m)
• Impedence: 4 Ohms
• Frequency Response: 65Hz - 27kHz
Dimensions
• Crossover Size (in): 4-9/16'' x 2-7/8'' x 1-1/4''
• Crossover Size (mm): 115.4mm x 73mm x 32mm
• Woofer Mounting Depth (in): 2-5/16''
• Woofer Mounting Depth (mm): 59mm
• Woofer Mounting Diameter (in): 5-11/32''
• Woofer Mounting Diameter (mm): 136mm
• Woofer Diameter (in): 6-1/2''
• Woofer Diameter (mm): 165.1mm
• Tweeter Mounting Depth (in): 18.3mm
• Tweeter Mounting Depth (mm): 3/4''
• Tweeter Mounting Diameter (in): 2''
• Tweeter Mounting Diameter (mm): 51mm
Power Handling
• Power Handling Capacity (Peak): 220 Watts
• Power Handling Capacity (RMS): 110 Watts
• CEA-2031 Power Rating: 110 Watts
ALPINE MRP-F550
General Specs:
4-channel car amplifier
Max Power: 4 x 180W
Max Power:2 x 500W
RMS Power @ 4 ohms: 2 x 250W RMS (4ohms, 14.4V-BTL, 0.3% THD)
RMS Power @ 4 ohms: 4 x 90W RMS (4ohms, 14.4V, 0.08% THD)
RMS Power @ 2 ohms: 4 x 125W RMS (2ohms, 14.4V, 0.3% THD)
90 watts RMS x 4 at 4 ohms (125 watts RMS x 4 at 2 ohms)
250 watts RMS x 2 bridged output at 4 ohms (4-ohm stable in bridged mode)
CEA-2006 compliant
2-, 3-, or 4-channel output
Variable high-pass/low-pass filters (50-400 Hz, 12 dB/octave)
Tuned Bass EQ (12 dB bass boost at 50 Hz for channels 3 & 4)
Subsonic filter (15 Hz, 24 dB/octave for channels 3 & 4)
MOSFET power supply
STAR Topology
Gold-plated screw terminals
Speaker- and preamp-level inputs
Preamp outputs
Fuse rating: 30A x 2
15-5/8"W x 2-3/8"H x 9-9/16"D
Don't forget the custom box built buy yours truely.
Sorry if we hijacked.
Focal 165 K2P 6.5 in front
and polyglass v2 in rear
They were not as bright as the MB quart and Infinity
