Sponsored by: Innova
Added AVIC Z2 now remote entry won't work
Old Oct 23, 2007 | 10:05 PM
minitech's Avatar
minitech
Default Added AVIC Z2 now remote entry won't work
I just changed out the Bose system completely and added an AVIC Z2 NAV unit. HU works great. I found the key fob no longer works to lock or unlock doors or do anything else. Anyone know if the car needs the Bose system to work or something? Is it something totally unrelated and I should look elsewhere beside the audio change out causing this? Thanks.
2000 Coupe
Old Oct 23, 2007 | 10:11 PM
provp's Avatar
provp
check your battery. If its the original it might be time to change out!
Old Oct 24, 2007 | 08:05 AM
minitech's Avatar
minitech
Tried that. Tried the other remote. Are we saying ordinarily when you take the Bose system out there should be no problem with the remotes/entry? I have a window valet also and like to use that.
Old Oct 24, 2007 | 08:54 AM
jj_adams319's Avatar
jj_adams319
The FOBs may just need to be reprogrammed. Its not a big deal to do, you can find the instructions on the forum. I've had to do that after disco'ing the batt B4.
Old Oct 24, 2007 | 01:29 PM
Mister Peebody's Avatar
Mister Peebody
From: Ok! So you don't believe in conspiracies, but will you acknowledge the possibility of there being coordinated activities in secret places? Texas
Standing on the driver's side, hold both the lock and unlock buttons on the fob until you hear the horn blow once. That'll probably do it.
Old Oct 24, 2007 | 04:02 PM
jbondfl's Avatar
jbondfl
From: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
Completely coincidental. The two are unrelated.
Old Oct 24, 2007 | 10:27 PM
minitech's Avatar
minitech
Excellent. Never thought about the battery being off for more than a week due to backordered parts.
Old Oct 25, 2007 | 07:10 PM
minitech's Avatar
minitech
Figured it out. Was the battery being out and the fobs were not synced. Held both lock and unlock by drivers door as suggested and all is well now. Thanks to the Forum!!
Old Oct 25, 2007 | 08:10 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
Weird on our 01 vert the battery is out all winter long and remotes always work, when had stock radio it saved all that as well
To Added AVIC Z2 now remote entry won't work
