Sponsored by: Innova
Static in my Alpine?
Old Nov 4, 2007 | 11:32 PM
VETTEHIGH's Avatar
VETTEHIGH
Default Static in my Alpine?
I get all stations, but static mostly all the time. When I use the Cd, everything is perfect. Any info on what could cause constant static with the radio playing? Thanks
Old Nov 5, 2007 | 05:21 PM
Fasthotrod's Avatar
Fasthotrod
Bad antenna wire.
Bad ground.
Powerful ignition system.
All kinds of things, bro.
Simple check might be to buy a cheap replacement antenna and plug it into the HU. Static clears up, and you know you got a bum antenna lead or mast.
Mark
Old Nov 5, 2007 | 06:35 PM
PFMC3's Avatar
PFMC3
is stero on local mode
Old Nov 5, 2007 | 08:10 PM
Nzzz's Avatar
Nzzz
Have you tried a noise supressor/filter yet? That might fix your problem.
Old Nov 6, 2007 | 08:26 PM
VETTEHIGH's Avatar
VETTEHIGH
Just put my C4 away for the winter, but I will have it out a few days a month if sunny and clear roads. Will check then
Old Nov 6, 2007 | 08:30 PM
PFMC3's Avatar
PFMC3
Oh this is a c4 you will need a noise supressor on the unswitched power line for the radio. You can purchase one at radio shack.
To Static in my Alpine?
