C6 Sirius Starmate Install
Here is the dock:
Here's the radio:
The location works pretty well. The display is blocked when the shifter is in 5th gear, but when cruising in 6th it is easily viewed.
I first tried just putting the antenna on the frame inside the rear fascia. That placed it kind of low. My sat reception was pretty marginal there. So I made a little shelf out of some sheet metal and a couple of pieces of 1x2. A couple of pieces of double sided adhesive tape on each of the 1x2s and I stuck it right to the bottom of the fascia above the passenger side tail lights. Reception is terrific with it mounted there.
Here is the antenna shelf:
I used an add-a-circuit to get power from the passenger footwell fuse block. I had a lot of trouble finding a circuit that wasn't always hot. I tried the driver's seat heater fuse (I don't have heated seats) but that was always hot. I ended up using the windshield wiper/washer fuse. That one turns off when the ignition is off. The only downside is that it doesn't run in RAP mode, but that's not a big deal.
