Question for you audio experts...
Here's the setup:
Focal front/rear speaker replacements
JL 300/4 Amp
JL Stealthbox
JL 250/1 Amp
My question is...I noticed that after having this stuff installed...it seems that the sound is mono, with no difference between left/right. I notice because certain songs that I know have distinct sections where stuff comes in either the left or the right aren't doing that anymore.
My wife's car has a similar setup with a JL 300/4 amp running replacement factories. Of course she also has a different car (xB, with an Apline HU from factory...also running a JL CleanSweep), but I play the same songs in her car and can pick up on the distinctive left/right variants.
So what's the deal here? Why did the installer set my system up to basically run mono. It's as if one output signal is going to all speakers, rather than having left/right and front/rear. Is this something because of the way the BOSE is or whatever? Otherwise, what can I possibly do, if anything, to get that left/right stereo in my current setup. I really think it's effecting the sound quality. The new stuff sounds great, but I do notice that it's a bit more flat sounding than my wife's system which sounds a lot more spacial.
Hope this makes sense...
I mean isn't that limiting the sound quality? wouldn't things sound a bit nicer if I had left/right difference? Like would the fronts sound a bit cleaner if they weren't running the same signal and they were running a true separate left/right signals?
Is it possible to have it setup that way rather than how it seems they did it tapping into the rears as you said?
Is this what needs done?
http://www.lazyassgeek.com/c6-stereo...-unit-harness/
And thanks for the tip...
Who knows though.
Lower rear speaker volume until you can hear the left and right disparity.
If you use the balance and fade what does it do, does it fade and balance properly.
To wire it how it is in that link so I need some type of interface adapter or what?
Thanks for the tips...I'm going back to the installer tomorrow to ask/complain...so I'm just trying to know just what to say/ask for/show him.
basically tell him you want it wired this way by splicing in to low level at back of radio. Your system should sound 80x better afterwards and fade/balance properly.
Also ask him what he was thinking splicing in at the rear speakers for you 4 channel amp, this might be ok for a sub, but not a 4 channel, and you are right the sound is mono how its setup currently.
Let me know what happens. If you need some to talk to him PM me and ill give you my number
this is how i always do it after doing 2 and getting crazy noise I went to the ground on the radio chasis and it worked great so I do all of them like that and its less splicing
First off, he wasn't sure why I'd want to tap into the low level at the back of the deck instead of the high pass. His take was that the low level would be beneficial to run the subs, but for the front/rears, you wouldn't want the low level line, you'd want the high level or whatever. Does that sound right or make any sense? Why would we want to run the front/rears from the low level instead of the high?
He did however agree that tapping into the rears and taking that two channel signal (mono) and running it 4 ways (fronts/rears) wasn't the ideal setup. He said he's using a line level converter in there already, buto he said he could run another line level converter to make the signal from the rears run 4ways and get the left/right separated.
I also showed that GM adapter thing and he said that wouldn't do anything different for the same above reasons...that it would just give the same low level outs.
However, after looking at the LazyAssGeek stuff some more...I'm wondering if I explained it to him wrong. I showed him that Low Level Out diagram explaining that's how he could get low level outs, and that's why he was saying it wouldn't make sense to run that way for the front/rears...but when looking at the "C6 Bose Speaker Wire Colors," I'm thinking that the high outputs are ALSO back there.
I'm confused now...
But...is this right...
That diagram showing the low level outs...are the high level 4 channel outs ALSO on there? So essentially, instead of having him keep the setup with the amp tapped into the rear high level output and running another line level converter...can he just use the high level outs as shown on this:
http://www.lazyassgeek.com/c6-stereo...r-wire-colors/
Sorry for being so much trouble...I'm just royally confused...
This is a stunning example of how there are installers, then there are kids who simply hook stuff up. Don't let this kid touch your car again.
So he SHOULD use the low level outs? And why?
Sorry for being so redundant...I just want to know EXACTLY what to say...
And again...why won't a CleanSweep work in the C6? I've read it's because the factory Bose puts out a "flat" signal. Does this mean there's no true, dedicated left/right/front/back being sent out? In other words if I have a track that puts one sound out of the left speaker, and another sound out of the right speaker and goes back and forth...I'd never be able to achieve that with the BOSE?
Saying a component is 'flat' is saying that there is no built-in fixed EQ. In other words, the factory CD player does not have a built-in bass boost to overcome the speakers' bass limitations, or vice-versa. Ideally you WANT a 'flat' output signal. The C6 NAV has a 'flat' output.
These things have nothing to do with your ability to balance the LEFT/RIGHT or FRONT/REAR settings. The reason you have that problem is because the speaker-level signal tapped by the "installer" (I'm being kind, here) is essentially mono and has some response irregularities because those speakers are being driven by a BOSE amplifier that does NOT have a flat output. They also contain more noise than the signal that originally left the CD player. Therefore you have to circumvent the factory amplifiers.
Make sense?
I will be sure to post results next week once he does the work. I can rest easy now, knowing everyone is on the same page.
Big thanks!
Is the signal at the rear speakers full range or is the bass filtered out?
Bose system/no nav 2005 C6
I want to use an infinity basslink that was given to me as a gift. I have it so I want to use it.
