Sponsored by: Innova
Help ASAP, C6 connectors
Old Nov 23, 2007 | 03:17 PM
jaki30's Avatar
jaki30
Default Help ASAP, C6 connectors
I am reassembling the dash on my C6. There is a plug that I cannot find where to connect it to.
It is white, 8 pin with just two pins wired. The wires are red and a red/blk.
It looks like it should reach the temperature controller or the area near the seat heater switches. Anyone??!!
Old Nov 23, 2007 | 05:33 PM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
Do you have heated seats? I forget what all of the connectors look like, but I do remember the seat heat connectors being flat and wide.
Old Nov 23, 2007 | 06:59 PM
jaki30's Avatar
jaki30
Default Yes, heated seats
I have the three connectors for the temp control.
The two heated seat connectors are wide and flat. Then there is the lighter connector. I have no clue what the little white connector is for and can't recall if I disconnected it from anything. It is two rows of four slots each. The connector is about 3/8" wide and about 1/2" long. I checked the OEM radio and there was no slot for such a small connector.
Does it belong to the base radio?
If anyone has the electrical schematic for the 05, it would tell what the connector was for.
Old Nov 24, 2007 | 10:06 AM
jaki30's Avatar
jaki30
Default Anyone with there C6 dash apart?
Desperately trying to figure out where this connector goes. I really don't want to wait for the dealer service dept to open Monday. Anyone?
Old Nov 24, 2007 | 03:40 PM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
Can you post a pic of it? Might make it easier to identify.
IIRC the connectors you pull when you remove the console are as follows:
Hazard Lights (up between the vents)
Seat Heater (2)
12V/Cig lighter in the ashtray
12V/Cig lighter in the console storage area
Active Handling/Traction Control button
If you have F55 there will also be a connector for the ride control.
Old Nov 24, 2007 | 11:21 PM
jaki30's Avatar
jaki30
Default Looks like it belongs to the NAV
http://img162.imageshack.us/my.php?i...ctor003pg7.jpg
http://img240.imageshack.us/my.php?i...ctor001wo0.jpg
http://img124.imageshack.us/img124/6...ctor002la2.jpg
I think it has been identified as belonging to the NAV system. I checked on the bay and saw a NAV unit for sale. The white connector on the back of the unit looks like the mate for the connector I have tried to describe.
To Help ASAP, C6 connectors
