I have a 1990 C4 very clean car with low miles. I was driving around the other day and the radio just quit working, no sound. The CD also does not have any sound. When you turn it on, the antenna goes up, it lights up and displays the station makes a strange noise occasionally. Any Ideas ? :confused:
replace the whole system. it is commonly referred to here as "Blows" or "Blose" because of the sound quality, and common failures like the ones you are experiencing. There are several C4 threads on replacing the system...look in this section, and also do a search of the archives. :cheers:
Drop test.
Step 1 Remove from car
Step 2 Drop on pavement from shoulder height
Step 3 Examine to see if it is many pieces. If not repeat step 2
Step 4 Throw out in garbage. Urinating on it in this step may also give a warm sense of satisfaction.
Step 5 Buy a real system and install.
Just my $.02
92TripleBlack
:cheers:
