Sponsored by: Innova
'07 base system
Old Dec 27, 2007 | 07:50 PM
dkrhardy's Avatar
dkrhardy
Default '07 base system
I have asked so many questions about this that I've lost track of where/what I've asked. I have been getting so many "opinions" yet no one seems to know the real answer.
Local shop SWEARS he can add a module to my BASE '07 system. On the forums it seems the majority think I need the base '08 system to add the module and have it work through the head unit.
Do I take a gamble that the local guy knows? He has to order in the "parts" and if it doesn't work, he will allow a credit toward an aftermarket system + I gotta pay labor. Hmmmm
PLEASE, anyone have 1st hand info?
Thanks,
Don
Old Dec 27, 2007 | 08:22 PM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
Thanks,
Don
Um... a "module"? What kind of module are you talking about?
If this guy claims there is any difference in the systems from '05-'08 aside from the addition of the AUX port in '08 then he doesn't know what he's talking about....
Old Dec 28, 2007 | 05:46 PM
dkrhardy's Avatar
dkrhardy
It is the XM receiver "module". The '08 aux port is what enables XM to be added to it and NOT the '07?
Old Dec 28, 2007 | 07:29 PM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
The '08 Aux port is what lets you put a portable XM unit that you have to control from the unit, not the integrated XM like the factory. What this guy is likely to install is a wired-in FM modulator where you'll tune in the stereo to an FM station and control XM via a separate unit. This still does not get you integrated control but it will definitely sound better than using a wireless modulator.
Though now I understand what you were originally asking I unfortauntely still can't answer the question with any certainaty. XM can be integrated like a factory install by your dealer, but I have no experience with the base system so I don't know if it's possible with that. If XM was offered as an option (I'm now 2 years removed from the buying process) for your car then it should be able to be added.
To '07 base system
