Sponsored by: Innova
AVIC Z2 DVD Hack Problem
Old Jan 29, 2008 | 10:22 AM
zich6's Avatar
zich6
Banned Scam/Spammer
St. Jude Donor '08-'09
Default AVIC Z2 DVD Hack Problem
My installer was running the cd in the AVIC that changes the firmware to allow DVDs to be played when the accessory power timed out and shut down power. The disk instructions warn that this could cause damage to the hard drive. After resetting the AVIC several times, the unit will still not recognizing data CDs and the software version still shows the original 2.0 version. Has anyone run into this? If so, what did you do? I've told the installer that if he can't fix the AVIC, he needs to replace it. Thanks.
Old Jan 29, 2008 | 10:29 AM
EVIL_C5's Avatar
EVIL_C5
Uber Waxer
Cruise-In 8-9-10-11 Veteran
CI 9, 10 & 11 Car Show Winner
St. Jude Donor '08-'10
did you check www.avic411.com to see if this is common?
Old Jan 29, 2008 | 10:42 AM
zich6's Avatar
zich6
Banned Scam/Spammer
No, but I will. Thanks.
Old Jan 29, 2008 | 07:57 PM
minitech's Avatar
minitech
Check the box for the date it was made. If made after June 2007 you do not need to do the CD upgrade. It will bypass with the two wire fix only.
Old Jan 29, 2008 | 08:07 PM
minitech's Avatar
minitech
If you find the system is really damaged due to the situation you can search the popular auction site for "AVIC Z2" and find choices of new hard drives from $99 to 180 that will have the most current maps and more space than stock. So at the worst you could end up with a better hard drive with most current software for easy bypass for some extra money. Who pays for it is up to you and the guy I suppose.
Old Jan 29, 2008 | 08:18 PM
zich6's Avatar
zich6
Banned Scam/Spammer
Thanks Minitech. A new hard drive from Pioneer is about $280. Question - if I buy an aftermarket HD as you suggest, is it plug-and-play? In other words do I just remove the old one and plug in the new one? Thanks.
Old Jan 30, 2008 | 07:56 AM
Fcal's Avatar
Fcal
Can I ask a stupid question?
Why the hell wasn't your car running while this was being done?
After reading that warning, I started my car up and left it running while I did the upgrade.
Don't let your installer off the hook for this one.
Old Jan 30, 2008 | 08:16 AM
EVIL_C5's Avatar
EVIL_C5
Uber Waxer
reading stuff like this, im glad I have not updated my Z1
Old Jan 30, 2008 | 08:33 AM
Fcal's Avatar
Fcal
Evil, I did the upgrade in my F-150 and it went off without a hitch. If you follow the directions on the Pioneer site, you should have no problems.
It's worth it. Now the NAV works like it should.
Old Jan 30, 2008 | 08:45 AM
zich6's Avatar
zich6
Banned Scam/Spammer
Can you provide a link to the "directions on the Pioneer site?" Thanks.
Old Jan 30, 2008 | 12:52 PM
Fcal's Avatar
Fcal
Go to www.AVIC411.com
They have alot of info on that site.
There is a link for a freezing issue on the Z2's.
If you install this upgrade, it sets up the Z2 to be bypassed.
The site also has info on how to do the bypass.
I did mine in about 20 minutes.
Old Jan 30, 2008 | 01:06 PM
zich6's Avatar
zich6
Banned Scam/Spammer
I got confused when you said "Pioneer site." I've looked at AVIC411. Thanks.
Old Jan 30, 2008 | 01:20 PM
EVIL_C5's Avatar
EVIL_C5
Uber Waxer
if my z1 is bypassed via the wireing harness, will the upgrade mess that up?
Old Jan 30, 2008 | 03:12 PM
Fcal's Avatar
Fcal
Can't answer that. Again, log ont to AVIC411.
There's lots of great info on there. Helped me out alot on the install and bypass.
Old Jan 30, 2008 | 09:08 PM
minitech's Avatar
minitech
If it were me I would buy the one on "The popular auction site" with 40 gig capacity for about $120.00 Yes it is plug and play. Don't even need to remove the head unit, the hard drive comes out the front just beneath the disc slot.
Last edited by minitech; Jan 30, 2008 at 09:16 PM. Reason: replaced brand name with generic name quoted
Old Jan 31, 2008 | 08:41 AM
zich6's Avatar
zich6
Banned Scam/Spammer
Thanks for the help. I have an appointment with my installer today. If he can't fix it, I may be looking at a new hard drive.
Old Feb 1, 2008 | 03:39 PM
BAND1T's Avatar
BAND1T
Great site!
That's where I got the hack and it took about the same amount of time .
TJ
Old Oct 30, 2008 | 09:38 AM
carjnkie22112's Avatar
carjnkie22112
1st Gear
Default pioneer avic z2 bypass
I just bought one a week ago and i love it.......... its great! and the pioneer avic z2 bypass works great.......thanks
To AVIC Z2 DVD Hack Problem
