Sponsored by: Innova
C5 Double Din Question
Old Feb 14, 2008 | 04:02 PM
Z06-Hammer's Avatar
Z06-Hammer
Default C5 Double Din Question
I bought the GMCRV2 and got all the speaker wires soldered up. Where does the Orange/White
To lighting switch terminal and Car speed signal input wire connect?
Old Feb 15, 2008 | 08:17 AM
VET IT B's Avatar
VET IT B
I would like to find out where the speed wire is located and how to find it as well.
Old Feb 15, 2008 | 09:04 AM
SublimeZ's Avatar
SublimeZ
From: Austin, Why are they tolling roads that are already paid for, Texas
From the faq
I have a navigation h/u that has to connect to a speed sensor wire, where is it?
You will have to tap into the harness on the instrument cluster. You need to find the Green/white (A7-circuit 817) with a tan/white (A6-circuit 33) above it and a black (A8-circuit 150 ) below it..The other green/white (A10-circuit 357) oil temp has a blank and a gray on each side.
Old Feb 15, 2008 | 11:31 AM
VET IT B's Avatar
VET IT B
Originally Posted by SublimeZ
From the faq
Thanks for the heads up.
Old Feb 15, 2008 | 02:47 PM
clayton1's Avatar
clayton1
Banned Scam/Spammer
2 spots I believe, At the PCM or the cluster.
(I got mine from PCM)
Old Feb 15, 2008 | 02:52 PM
Z06Joe@AutoBuffs's Avatar
0Z06Joe@AutoBuffs
Former Vendor
St. Jude Donor '08-'09-'10
PM Shagster... he does this for a living and is a vette stereo guru!!!!
Old Feb 15, 2008 | 03:22 PM
Z06-Hammer's Avatar
Z06-Hammer
Do you remember what pin number it was on the pcm?
Old Feb 17, 2008 | 09:20 PM
Dave84/76's Avatar
Dave84/76
My info says pin #50 in the red plug at the PCM.
Old Feb 18, 2008 | 01:14 PM
Archdog75's Avatar
Archdog75
The wire for Illumination is needed to be tapped into the HAVC behind it in the wire harness. Its a cream colored wire on one end of the harness. There's a pic in the FAQ about this.
About the Speed Control wire, I tapped into the green/white stripe wire in the stock wire harness for the original stock sterreo. The stock sterreo uses the speed to adjusts the volume as you increase your speed. I believe someone posted a pic of that wire. I tapped into it for my avic d3 and I have no error messages and I checked the wire connection in the menu of the avic d3 and it said "Connected" and it displays my speed.
Its easy to install, I thought it was going to be hard, but its not really.
Justin
Old Feb 18, 2008 | 01:20 PM
Archdog75's Avatar
Archdog75
Illumination wire:
Speed Sensor wire:
Hope that helps you,
Justin
Old Feb 18, 2008 | 02:59 PM
Z06-Hammer's Avatar
Z06-Hammer
Thanks for the info guys. Finished up the install last night and everything works perfectly! I went ahead and tapped into the VSS wire behind the insturment cluster and did the blue LED mod to the side controls while I had the cluster out.
To C5 Double Din Question
