Sponsored by: Innova
Rear speaker replacement for convertible?
Old Feb 25, 2008 | 08:52 AM
LTCHAPPA's Avatar
LTCHAPPA
Default Rear speaker replacement for convertible?
What would be a good quality replacement for the rear of the C5 convertible? The Bose speakers are 5.25.
Old Feb 25, 2008 | 09:14 AM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
i recommend polk db 5.25" i believe its called a db521
Old Feb 25, 2008 | 10:21 AM
BigButtLover's Avatar
BigButtLover
St. Jude Donor '08
i wouldn't replace these. You will hardly be able to tell any difference.
Old Feb 25, 2008 | 01:23 PM
pentavolvo's Avatar
pentavolvo
I find on the C5 its much more noticable when you change them then on a C6 where the difference is nill. IMO do the front 3.5s first
Old Feb 26, 2008 | 06:37 PM
slplank's Avatar
slplank
I'd go ahead and change them and pentavolvo has recommended a good speaker that I know will fit (I put them in mine) and is not too expensive. I recently purchased a set at Circuit City for $90 and they are called DB521 as he states. It's an easy swap to make and I can hear a difference but mostly with the top up. I have an amped after market system though. The available speaker depth on the rears is very limited which narrows your options considerably. Using a spacer ring between the speaker and car panel you are mounting against allows you more spearker choices but the ring can't be more than about 3/8" or it will push the speaker face against the speaker grill panel.
To Rear speaker replacement for convertible?
