Sponsored by: Innova
D_boy Need Advice - Pop through Speakers
Old Feb 25, 2008 | 05:33 PM
CCrane65's Avatar
CCrane65
Default D_boy Need Advice - Pop through Speakers
When I turn on my Wipers I get a pop through the stereo. I am thinking I need to find a new place to ground the radio but wanted get your opinion. I used the same power and ground as the factory radio for my after market unit.
cc
Old Feb 25, 2008 | 05:35 PM
spedaleden's Avatar
spedaleden
You want to keep all of your grounds togehter at one location.
What Radio?
R U using an amp?
May need a ground loop isolator!
Old Feb 25, 2008 | 05:46 PM
Kid Vette's Avatar
Kid Vette
Might want to post in Audio/Electronics,
CCrane65's Avatar
CCrane65
What Radio?
R U using an amp?
It is a Jensen MPA6611X 4 channel unit 18 Watts RMS@4ohms.
Two actually, one RF Punch 400a for the front speakers and one Kenwood KAC-8101D for teh sub.
I purchased one of those things to take out alternator whine and it did a pretty good job of that.
I don't know what a ground loop isolator is though.
Old Feb 25, 2008 | 05:52 PM
spedaleden's Avatar
spedaleden
It sounds like it comming from the head unit. Make sure power from the radio and 12 volt hot all the time can go to the factory wiring. I would connect the radio ground to metal as close to the radio as possible. Make the the two amplifier grounds are together and not seperate. That head unit is prone to noise, but the amps should give you no problems
Old Feb 25, 2008 | 05:55 PM
CCrane65's Avatar
CCrane65
Which amp is poppoing? My guess the Jensen
I'm not using the onboard amps in the head unit. I'm feeding RCA to the Rockford amp, then from there pass-through to the Kenwood.
cc
Old Feb 25, 2008 | 06:00 PM
spedaleden's Avatar
spedaleden
cc
Ground loop isolator goes in line with the RCA cables. You plug these into the RCA's from the radio and then plug your RCA's from the amps to the isolators. You can pick these up at radio shack.
Old Feb 25, 2008 | 06:08 PM
CCrane65's Avatar
CCrane65
Ah-ha, I'll go check them out.
Old Feb 25, 2008 | 06:48 PM
Durango_Boy's Avatar
Durango_Boy
If that doesn't solve your problem an easy fix is running your own power and ground wires from the battery to the head unit, and using a relay to power on the head unit. Tap into the 12V constant line for the relay, and trigger it with a switched source like the one you are already using for the head unit's switched input.
Old Feb 25, 2008 | 08:35 PM
CCrane65's Avatar
CCrane65
I do happen to have some relays left over from an aborted headlight project when I had a C5.
Thanks DB, I'll keep that in mind.
Old Feb 26, 2008 | 07:53 PM
CCrane65's Avatar
CCrane65
Ok, I plugged in the ground loop isolator an it cut out my left channel and introduced alternator whine in place of it.
When I put the regular cable back in everything was back to normal.
The isolator did significantly reduce the pop from my wiper switch but at quite a cost.
Looks like I need to run the head unit ground back to the same location as the amplifiers.
Anything else I should do? Do I need to wire a relay in?
Old Feb 26, 2008 | 08:33 PM
Richard454's Avatar
Richard454
There are three ways that your car stereo gets noise-
1)Radiated through the air (“radiated noise”)
2)Induced -as a difference in voltages that reach each component ("ground loop noise”).
3)Line noise or “power line noise“
How to diagnose? Run a power and ground DIRECTLY to the battery for the radio & amp. if you still get a "pop" my guess is it's radiated through the air-Since fiberglass is a really bad at shielding. If it's not a pain try MOVING the radio out of the dash-or push any harness AWAY from the radio. If this solves it you can wire tie the harness up from the radio. If you still have a pop-you might want to try a noise filter at the wiper's power source. It sounds as though you DON'T have a ground loop problem.
Richard
Old Feb 26, 2008 | 08:39 PM
Durango_Boy
Running the head unit's constant 12V and ground to the battery is an easy task, and the relay to turn on the head unit is only a precaution, taking any harness noise out of the loop. By using a relay, you're only using the harness wire to trigger the relay, which gives the head units switched power directly from the battery.
Using an IGN lead to turn the head unit on, might leave you open to the same interference you are battling now.
Old Feb 26, 2008 | 08:48 PM
CCrane65's Avatar
CCrane65
Thanks guys. I guess I do have the option of leaving it as it is and living with the wiper pop on those very rare occassions that they are used.
By the way, I'm sure I forgot to mention it but the pop comes in when I turn the wipers off, not on.
cc
To D_boy Need Advice - Pop through Speakers
