Sponsored by: Innova
Need Help With C5 Bose Upgrade
Old Mar 8, 2008 | 05:37 PM
jeffrow68's Avatar
jeffrow68
Default Need Help With C5 Bose Upgrade
I've read the sticky on upgrading the C5 sound system, there is too much info there! I just want to keep the Bose system, add an amp, and a set of rear speakers with a sub.
What is the best way to wire in an amp? Can I tap the rear speaker inputs or do I need to get an adapter? If I need an adapter, which one do I get and where do I get it from?
I'm planning to add 2-8" speakers to the side rear storage covers in my 01 coupe. I'm planning on putting the amp and woofer in the center compartment, mounting the sub in the compartment cover and the amp inside the compartment.
Basically what I'm asking is how do I install and wire an amp to the existing Bose system? I'm not sure if I need a wiring adapter, or which wiring adapter works best, or where to find one. Thanks for any guidance. Jeff
Old Mar 8, 2008 | 05:51 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
well the C5 FAQ deff discuses this and yes there is lots of info becuase the bose is a weird system
you CAN NOT tap at the rear speakers the lows arent there. PACAOEMVET1 google it
Old Mar 8, 2008 | 05:57 PM
markcz's Avatar
markcz
That sounds like how I started with my '01
The easiest way would be to buy a PAC AOEM-Vet1 to get the audio signals to your amp, then tap into the OEM amp power circuit to use it as the trigger for your aftermarket amp (to retain RAP). Check out my RAP how to in post #9 of the C5 Audio FAQ thread.
Old Mar 8, 2008 | 08:20 PM
pentavolvo's Avatar
pentavolvo
in reference to rap power how to u dont have to pull the fuse box etc, there is a remote wire behind the stock radio
Old Mar 11, 2008 | 06:20 AM
VET IT B's Avatar
VET IT B
Just want to see if I am doing this ok. On a Z2 HU. The Pac OEM1 the pin connectors to the factory radio connectors seam to be just plug & play.
On my power lead for the HU I have 4 pairs of colored wires, 8 total. I connect these same colors to the Pac wire colors and and just leave the remaining 10 wires alone. Does this sound correct? Thanks, Mark
Old Mar 12, 2008 | 06:39 AM
VET IT B's Avatar
VET IT B
TTT Any help?
Old Mar 12, 2008 | 07:28 PM
VET IT B's Avatar
VET IT B
ttt
To Need Help With C5 Bose Upgrade
