Sponsored by: Innova
First attempt using ABS /MEK molding method
Old Mar 11, 2008 | 06:41 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Default First attempt using ABS /MEK molding method
After trying all sorts of other methods, I've decided to give the MEK/ABS method a try. Thusfar I've mixed a handful of ABS shavings with about a half cup of MEK.
a) about how long should it take to become a sludge?
b) how exactly do you apply the sludge?
thanks.
Old Mar 12, 2008 | 06:37 AM
VET IT B's Avatar
VET IT B
Using ADS and Acetone, mine started to desolve to a slurry almost instantally. It was ready to use in about an hour.
Application was with a popsickle stick, sometimes with the tip of a rubber spacula and sometimes with my finger. Hope that helps.
Old Mar 12, 2008 | 10:51 AM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
For some reason, mine's not dissolving that quickly. Does Acetone work faster than MEK?
Old Mar 12, 2008 | 11:08 AM
scott_fx's Avatar
scott_fx
mek works faster the abs. you probably didnt use enough abs, it breaks down A LOT. Is it not dissolving or has it dissolved and it isn't thick enough? if it hasn't dissolved you can try to agitate it a little by stirring it gently. if it's just not thick enough you can add more shavings or keep the cap off and let the mek evaporate a bit
Old Mar 12, 2008 | 05:38 PM
VET IT B's Avatar
VET IT B
How did you make your abs? I used a hand planer, so the shavings were very thin. If your pieces are too large or thick it can take a long time to disolve.
Old Mar 12, 2008 | 05:48 PM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Turns out the pipe i was using wasn't ABS. I found some old dash parts i cut off and shredded them. They melted in about a half hour. Finding REAL ABS here is a pain. luckly i have a few more spare dash parts and can probably salvage some more from a local junkyard.
Old Mar 12, 2008 | 06:41 PM
FL_Dave's Avatar
FL_Dave
I wouldn't use your finger with MEK. Studies show that MEK is absorbed through the skin and damages one's liver. Use a popsickle stick or spatula. Common rubber gloves won't survive exposure to MEK.
Acetone works fine. I just used tin snips to cut strips from ABS pipe and let it soak in acetone in a squeeze bottle for a couple of hours. It seems that more ABS is needed than acetone.
To First attempt using ABS /MEK molding method
