Sponsored by: Innova
avic d3 install with a problem
Old Mar 19, 2008 | 09:04 PM
saloonwarrior's Avatar
saloonwarrior
Default avic d3 install with a problem
I just installed a d3 and have an issue. I only have the rear speakers hooked up right now (making templates for the components up front). I ran regular speaker wires to the rears. Every once in a while, the speakers cut out for a couple seconds, then come back on. This happens while playing music or dvd's. Any ideas??
Old Mar 19, 2008 | 10:05 PM
805Z06's Avatar
805Z06
My guess...
I would check
1) Solid RCA connection from HU to Amp
2) Solid Speaker connection from Amp to speaker
3) Make sure your ground is solid
4) Make sure all power connections are solid
5) Check Amp settings, is gain too high?
What are Amp and speaker specs (watts)?
Is there a cross over in the equation?
Old Mar 19, 2008 | 10:34 PM
CraigE's Avatar
CraigE
Why would you want rears???
Old Mar 20, 2008 | 12:00 AM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
prly a loose wire or a bare wire shorting out against somethin metal
Old Mar 20, 2008 | 07:22 AM
saloonwarrior
I am not running an amp to them....they are factory bose. I am using them to make sure everything is working correctly. So basically I eliminated everything from 805Z06 except for the ground. And I don't think it is that because the hu doesn't go off, just the speakers. As for a loose wire, how would this make them both go out? I'm open to all ideas.
Old Mar 22, 2008 | 03:33 PM
CCMS21's Avatar
CCMS21
Did you disconnect the factory speaker wire to the speakers?
Old Mar 22, 2008 | 09:05 PM
saloonwarrior
Yes, I cut the factory plug off, spliced the wires to the heavier wire I ran from the head unit, then plugged them into the speakers. What are these speakers rated at? I a little lost??
Old Mar 23, 2008 | 03:15 PM
805Z06's Avatar
805Z06
Any status?
Does it cut off on high volume?
Old Mar 25, 2008 | 09:30 PM
saloonwarrior
No, it doesn't cut out at high volume.....but they sound like ****, so I don't leave them cranked......hoping to get the components in this week possibly...making the templates right now.
To avic d3 install with a problem
