I installed a Delco-Bose CD changer in a '98 with a purchased "correct" cable; power is at the changer but no input to the head. The 4-wire connector was found and power was tapped from the 3-wire pigtail. Pressing the CD/ Aux button twice does nothing. Did I miss something?
I connected all of my wires into the harness behind the fuse panel. there are two dark green wires in the harness (data buss) that match the color of the dark green wire on the changer harness, try one, if it still dosen't work then try the other one.
check the tech tips section for install directions. :cheers:
