Bose Subs help
Apr 7, 2008 | 11:40 PM
so there should be 2 light blue wires ?
Apr 7, 2008 | 11:44 PM
Cruise-In IX Veteran
just one common for everything
Apr 7, 2008 | 11:45 PM
ok so in total i gotta tap 3 wires
Apr 7, 2008 | 11:50 PM
yes sir. LF RF and that common
Apr 7, 2008 | 11:59 PM
you are the man thanks alot for your help another quick question what would the other rca`s be for?
Apr 8, 2008 | 10:46 AM
i'm guessing to plug into the aftermarket radio to signal the front subs to work using the RCA jacks in the back?
Apr 8, 2008 | 10:55 AM
So before i go get everything, you basically convert the LR RF of the Bose harness into RCA's and put them into the preouts on the back of the new radio? and then ground out the Common ground? What wire there is the switched power? Thanks~Cole~
Apr 8, 2008 | 10:18 PM
Apr 9, 2008 | 12:50 PM
Apr 9, 2008 | 09:25 PM
which one? the Soundgate one? or another one?
Apr 9, 2008 | 10:22 PM
soundgate is my recommendation
