Sponsored by: Innova
Bose Subs help
Old Apr 7, 2008 | 06:11 PM
lexizpimpin's Avatar
lexizpimpin
Default Bose Subs help
can anyone help me out i want to have the oem bose subs work but i dont want to get the adapter because i will switch out in month for all new speakers etc
but for now can anyone tell me which wires go where from the smaller plug on the radio harness so i can connect that to my radio?
Old Apr 7, 2008 | 06:25 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
first off make sure ur turn on lead is connected in the main harness
you will need to splice rca ends in to plug into the preouts on ur radio
LF tan/black
RF lt green/black
LR brown
RR dk blue
comon lt blu
i believe you can get away with only connecting 2 of the channels, which 2 it is i dont remeber. id try just the front channels otherwise do all 4
Old Apr 7, 2008 | 07:11 PM
lexizpimpin
which wire did the turn on lead have to be connected can you write on a picture of the plug
Old Apr 7, 2008 | 07:12 PM
lexizpimpin
i hope he doesnt mind
http://i118.photobucket.com/albums/o...0/101_0522.jpg
lexizpimpin
Old Apr 7, 2008 | 07:15 PM
lexizpimpin
this picture describes more of what i need thanks
Old Apr 7, 2008 | 07:23 PM
pentavolvo's Avatar
pentavolvo
im pretty sure i went over what color is what on the sub amp harness... turn on is listed in the FAQ. i no longer have diagram in front of me.
fyi turn on should match up with ur gm harness
Old Apr 7, 2008 | 07:28 PM
lexizpimpin
so the other wires other then the wires you mentioned arent used?
Old Apr 7, 2008 | 07:41 PM
pentavolvo's Avatar
pentavolvo
correct.... you are only using 5 wires all next to eachother
and like i said if i recall you only need to connect one pair of them. connecting just the FL and FR should get you the bose subs along with the common. now i have no clue if the bose amp has low pass built in or not so you might wanna connect em to the sub out of ur radio and enable your low pass filter to 80 or 100hz
Old Apr 7, 2008 | 07:45 PM
pentavolvo's Avatar
pentavolvo
metra 70-2004 isnt the expensive and should work without splicing
the picture thats shown for the harness is wrong i installed one for a customer its a 2 part harness. the 2nd part has the rcas and matches the bose plug and the other main harness is the same as a regular gm harness
Old Apr 7, 2008 | 07:47 PM
pentavolvo's Avatar
pentavolvo
what it really looks like as every website shows it wrong
Old Apr 7, 2008 | 08:33 PM
ColeTrain'sC5's Avatar
ColeTrain'sC5
i don't mind ya using the pics. What adapter is there to buy so i can retain the bose setup with an aftermarker player? And where can i get one?~cole~
Old Apr 7, 2008 | 11:03 PM
lexizpimpin
perfect exactly what i was looking for any bigger pictures of the adapter? so i can see the pin outs
Old Apr 7, 2008 | 11:05 PM
pentavolvo's Avatar
pentavolvo
i gave u the pinouts already
Old Apr 7, 2008 | 11:06 PM
lexizpimpin
im still kind of confused lol i would prefer to see a bigger picture of the adapter if possible
Old Apr 7, 2008 | 11:07 PM
lexizpimpin
but thank you
Old Apr 7, 2008 | 11:17 PM
lexizpimpin
also what did you mean by saying common is blue?
To Bose Subs help
Old Apr 7, 2008 | 11:21 PM
pentavolvo's Avatar
pentavolvo
i dont have a bigger pic
common is the common for the rcas
Old Apr 7, 2008 | 11:26 PM
lexizpimpin
you mean ground?
Old Apr 7, 2008 | 11:34 PM
pentavolvo's Avatar
pentavolvo
common ground same thing, but yeah
