Sponsored by: Innova
C5 - Aux Power Routing
Old Apr 19, 2008 | 11:00 PM
Autobot's Avatar
Autobot
Default C5 - Aux Power Routing
I am wondering if there is any way to feed aux power from the passenger footwell into the radio area. I found the bundle of cables that is in the footwell but can't see a way to feed them up there.
Old Apr 19, 2008 | 11:52 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
pull the carpet back a bit on the side it will deff feed right up there no ?s asked
Old Apr 20, 2008 | 04:06 AM
Autobot's Avatar
Autobot
Does the carpet just pull out, I don't want to pull it down and then not know how to get it back into the proper position. I will take a closer look in the morning.
Thanks.
Old Apr 20, 2008 | 11:52 AM
pentavolvo's Avatar
pentavolvo
you know what pull down the plastic cover under the glovebox its 3 plastic pushpins then you will be able to see clear as day how to feed it up there, otherwise if you pull the carpet out a bit you can work it back in
To C5 - Aux Power Routing
