radio noise
i have the stock setup bose speakers and stock radio i would like to keep it. so what i did was added a sub and amp hooking up the power wire and ground wire from amp to battery. everthing works except when i trun the radio down i hear the car noise in it really bad and plus if i hit the brake or trun a signal on the sub will bounce like a big bass note has hit it . so i changed the amp it didnt help .
does any no what else to try to me it seems like i am having ground problems but the wire is hooked direclty to the ground on battery ..
give me some ideas and i will try . i even hooked th ground to chassie and it did no good.
thanks a lot
