Sponsored by: Innova
Nav System Install Questions
Old Apr 27, 2008 | 12:22 AM
Sincleanser's Avatar
Sincleanser
Default Nav System Install Questions
Since many of you have already done this install and have done beautiful work doing so, maybe someone can give me some clarification on the parking switch?
Both my HU and the Nav moduale have parking brake switch leads. My question would be if I leafve them un connected will the system still operate normally? Do I have to hook them up? Can it be "worked around"
Thansk for any help you can give!
Old Apr 27, 2008 | 12:27 AM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
depends... what radio
Old Apr 27, 2008 | 12:30 AM
Sincleanser
Humm, Its kenwood KVT-512 with the kenwood KNA-G510 nav unit. Both have a light green lead labeled park switch. Im assumingthis is to eliminate function if the brake is not on.
Old Apr 27, 2008 | 12:34 AM
pentavolvo's Avatar
pentavolvo
yeah take both of those wires from the kvt-512 and nav add on and ground em to bypass all the bs, and just tape off the wire from the harness
To Nav System Install Questions
