Sponsored by: Innova
Sub solution for C5
Old Dec 17, 2001 | 12:20 PM
Chris@VetteFinders's Avatar
Chris@VetteFinders
Platinum Supporting Dealership
Default Sub solution for C5
I thought I read a while back that there was a company that made a ready to install, no modes required, (other than mounting) sub solution for the C5 that goes in the center compartment. I can't seem to find that.
Old Dec 17, 2001 | 12:53 PM
AP's Avatar
AP
Default Re: Sub solution for C5 (Rhys)
Its a JL Audio Stealhbox...
Old Dec 17, 2001 | 01:09 PM
Chris@VetteFinders
Default Re: Sub solution for C5 (NewVetteLover)
Where can I buy it and what is a recommended amp for it?
Thanks!
Old Dec 18, 2001 | 03:25 PM
Sam Lin's Avatar
Sam Lin
Check JL's site for a local dealer, expect to pay around $500 for it, it's overpriced, but it is an easy drop-in. A good amp? Something like RF's 400a2 would work, you want 300-400watts or more into one 4 ohm channel for it.
Sam
Old Dec 18, 2001 | 03:32 PM
Chris@VetteFinders
Default Re: Sub solution for C5 (Sam Lin)
Man, that is crazy! :crazy: Looking at $750 for adding a sub? NUTS! Double what its worth
Old Dec 18, 2001 | 03:55 PM
Sam Lin's Avatar
Sam Lin
A cheaper, better alternative is to have either a local shop, or you, fiberglass an enclosuer yourself. A number of people have done it on here and posted pics, and can help you with it. The materials come out to under $100, the labor depends on the installer and experience. Add your sub, which you then get to choose (JL still isn't a bad choice), and an amp, and you're looking at about $300-$400 for everything + labor if you have someone else do it.
Sam
Old Dec 18, 2001 | 04:23 PM
99HT's Avatar
99HT
The cheapest install would be a Bazooka. Tap the pre-amp outputs in the HU. You can always upgrade later.
Old Dec 21, 2001 | 04:32 AM
molon labe's Avatar
molon labe
or you can call Aubrey at BrandsMart in Overland Park, KS. he made mine and has molds to make more. i bet his price is much better than JL's.
pics of mine, from start to finish, on my web site - http://www.genocide2600.com/~tattooma/
Old Dec 21, 2001 | 10:43 AM
Chris@VetteFinders
Default Re: Sub solution for C5 (tattooed)
Thanks for posting that link. Why was the mold for the storage compartment needed? Is there something in the void space under the subs?
Old Dec 21, 2001 | 04:20 PM
molon labe's Avatar
molon labe
yes, the mold was used to construct a fiberglass closed (sealed) box. get better, tighter, more accurate bass that way.
Old Dec 21, 2001 | 04:33 PM
DocSandy's Avatar
DocSandy
From: When I say who is the mastah you gotsta say Shonuf
I have an extra drop-in box that is cut to hold a 10" sub. I had my Kenwood db+ in it. I upgraded to a 12" sub and had a new one made. The box sits about 1 1/2 inches below flush in the center compartment so you can still put the compartment lid over it if you want to. (I didn't want to cut a hole in my lid.) It is a perfect fit with the appropriate amount of volume for a Kenwood 10 but isn't carpeted. It's just bare wood at this point. It doesn't bounce or slide around any. I will get you some pics if you are interested. Also if anyone else is interested, I can have more made relatively inexpensively. I was really pleased with the guy's work when he first made it and asked him if he would be able to make more if the guys at CF wanted some. I'm not too sure how much but it will be yet but I'm thinking of somewhere in the neighborhood of $70 shipped.
MS
Old Dec 23, 2001 | 08:27 PM
LoneStarFRC's Avatar
LoneStarFRC
Yeah and it sounds great too. :yesnod:I'm using their 250/1 amp to drive it. Also added Boston co-ax's in the rear to replace the puny single cones.
To Sub solution for C5
