Sponsored by: Innova
Antenna Wire Q
Old May 16, 2008 | 11:15 PM
94flavette's Avatar
94flavette
Default Antenna Wire Q
I redesigned the stereo layout in my 94 and relocated the antenna wire to the HU and eliminated the box and wiring in the hatch compartment. When I ran a new wire from the antenna to the HU I needed a short (3' or less) wire with male antenna connections at both ends to finish the connection.
I've seen it online somewhere, but can't seem to find it. Any ideas?
Old May 17, 2008 | 10:24 AM
Champ156's Avatar
Champ156
Try METRA www.metraonline.com they make it last time i checked.
Old Feb 21, 2023 | 11:01 PM
jpatrick62's Avatar
jpatrick62
On my 69 convert, the antenna wire ran with the rear wiring harness. Goes along the sill plate on the driver's side, climbs up the rear brace and then runs on the top of the wheel hump. There are several wire hold downs along the way. Exits to the rear driver side quarter in its own hole along with the rear wiring harness, which also has its own hole to transit. You could probably just pull the carpet back a bit and re-glue it if necessary. Will probably be a 3 hour job including cleanup.
Old Feb 23, 2023 | 07:49 PM
VinceC5's Avatar
VinceC5
Metra 40-UV42 Antenna Cable Coupler
To Antenna Wire Q
