General speaker questions
Also, what materials are good for making enclosures/adapters with? I'm going to design adapters to make everything fit behind stock grilles, for a clean, stock look.
My system so far is a Kenwood MP3 compatible CD deck, a Sony Xplode 50wx4 channel amp, Pioneer 6x9s for the back. I still need to get front speakers and wires.
I finished removing all the speakers last night, and started working on getting the head unit out. It's been a fun project, and i'm looking forward to getting it finished...can't wait to hear how it sounds... :cheers:
thanks for the help...
chris
You want to seal the front of the speaker from the back of the speaker. Since speakers are mounted in a sub boxes for example, this means a sealed box. Sealing can also mean mounting them in a door. This is sealed from the interior cabin by the door panel. If you have a speaker with the rear exposed in the same air space, this is called free-air. You can also tune free air with ported enclosures. These are generally only used for subwoofer applications. If you don't seal a non-free air speaker from the cabin, you will loose most of your bass. So for your speaker sizes, make sealed enclosures. You can also put some polyfill into the sealed boxes. This will trick the speaker into thinking its in a bigger box and give you some more bass. Fill the enclosures about half way with polyfill. This is the stuff you use to put in stuffed dolls and can be bought in a pillow size bag at craft stores for $5.
The real output of the amp is about 25x4. The deck is OK. The speakers aren't very good. Look at the RX series on http://www.bostonacoustics.com for some good speakers front and rear. Skip the seperates, the amp doesn't make enough juice to power any. Use 8 gauge power and ground wire, ground to the frame in the rear. Get a 30 amp fuse, fuse holder, and GM battery tap for the power and put the fuse in the engine compartment. Run 12 gauge wires to all the speakers from the amp. Use good RCAs like Phoenix gold or Monster.
Hope this helps
:cheers:
[Modified by 92TripleBlack, 1:02 PM 12/19/2001]
[Modified by 92TripleBlack, 1:04 PM 12/19/2001]
It would be interesting to compare some of the high end/low end stuff, and see how much difference there is, and if it is worth the price.
thanks again for the info! :cheers:
Oh...on my amp, you said it was probably more like 25w per channel. Why would a manufacturer overrate their equipment by 2 or 3 times the wattage? How many watts per channel is really necessary? I don't need a lot of volume, but do more watts make better sound somehow?
chris
Watts don't make anything sound better, they allow speakers to be played louder without distorting. Speakers are usually rated with two figures. Continuous and max power. You'll see for example 50w continuous, 100w max. They will run perfectly fine with 10w but will start to distort probably not much above speaking level. And distortion is what causes speakers to blow up or fry. If you start to notice your speakers do not sound just as clear at higher volumes as speaking level, this is distortion. Flapping and clipping are the most severe forms of distortion and can destroy a speaker on the spot.
Lastly, speakers have efficiency ratings. Efficiency is how efficiently the speaker translates power into noise. Most seperates need more power to make the same amount of noise as they are more inefficient. Most cheap speakers are very efficient but not accurate in their sound reproduction. The good speakers use the power to get accuracy and clarity. So a pair of inefficient speakers with 75w of power will make the same amount of noise as a pair of efficient speakers with 25w of power but they will sound much clearer.
Hope this "clears things up"
I'll have to look over my amp's specs to see how it is rated.
