OK, My car is torn apart and I need to get it back together ASAP. 03 Z06 with Bose. I'm adding a 12" sub powered by an Alpine mono amp and keeping all the factory Bose, head unit, speakers, everything. I've read the FAQ and did several searches and can't figure what wires on the back of the Bose to tap the input of the sven2 harness to. Also, what can I use as a remote turn on for the amp that will still have R.A.P. The sven wiring instuctions are very vague Thanks for any help, I'm desperate. Rain
On the bigger connector dark green pin 8 is ur remote turn on. There are 2 dark green wires so make sure you are on pin 8 or test with a volt meter. Also if i recall the slots on both sides will be blank on the correct wire. I believe the wrong dark green is directly next to an orange
Ok onto ur sven2. Both switches go to rca
(all these wires are in the one smaller seperate connector that also has 1 or 2 bare wires in it
Take the 2 common wires from ur sven 2 (ie the negatives) and connect them to lt blue
Left positive is tan/black
Right positive is light grn/black
Thanks penta!! As always you are the man, I was hoping you would chime in, you're on here more than the moderators
You see the closeouts on the 13kv2s on elementals web site? Made my decision a lot easier, thanks for turning me on to them. Hopefully I'll be able to finish up the wiring tomorrow and get the beast back together now that I have an idea what I'm looking at. Thanks again bro, Rain
haha i grabbed a bunch of closeouts 13ovs a month ago and flipped em, ill be at there place for open house this weekend and am takin home a few kv's to hang onto for ppl... its a great sub and hell at 50 bucks why not.
