Sponsored by: Innova
Removing the CD Changer Brackets
Old Jun 11, 2008 | 09:34 AM
95BlueBomber's Avatar
95BlueBomber
Default Removing the CD Changer Brackets
What a pain! Why does nobody have detailed instructions on this? I got a sub for my car and had to remove those brackets it was time consuming to say the least. I am doing another install this weekend and may take some photos.
Old Jun 11, 2008 | 10:00 AM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
its only 3 bolts i never found it to be hard at all
Old Jun 11, 2008 | 10:07 AM
95BlueBomber
I guess it depends on the year. On my 99 FRC I had to cut the bolts that were going through the brackets and push them out the back. They were in a tight spot up against the frame rail so they had to be cut.
On this next install its a stock unit so I am going to have to relocate the changer. Its a 98, does anyone know what I am going to need to do on this one?
Old Jun 12, 2008 | 09:14 AM
95BlueBomber
anyone out there?
Old Jun 12, 2008 | 04:15 PM
95BlueBomber
come on guys dont let me down here...
Old Jun 12, 2008 | 04:23 PM
pentavolvo's Avatar
pentavolvo
i dont get what u are asking
if ur relocating the changer unbolt it or whatever and bolt it up where u want it
Old Jun 12, 2008 | 04:28 PM
95BlueBomber
the problem is the bracket that is left there after you remove the changer... I have a subwoofer box that is going in the compartment and the bolts are in the way.
Old Jun 12, 2008 | 05:44 PM
rcs128's Avatar
rcs128
I recall it was a PITA on my 99 coupe, too. I think they were riveted in there.
Old Jun 12, 2008 | 08:30 PM
pentavolvo's Avatar
pentavolvo
on the later model C5s the bracket unbolts and just the studs are left and generally arent in the way and if they are u saw em off
To Removing the CD Changer Brackets
