Yes, the ground is going to a distribution block. The block is for + and -
It isn't bolted down bare wire. It is 0/1 gauge and the grounding terminal is bolted to the seat belt bolt. I know there are a few stray wires sticking out. I lost the hex head screw that is supposed to secure down the wire. So I went to home depot and bought a bolt that fit the hole. So I installed it in the Home Depot parking lot. Where could I find a little hex head screw to replace the original?
A ring terminal wouldn't have near the contact patch of the grounding terminal.
The distribution block i got will be in the rear pass side compartment in the trunk you think its fine if i run a 4 gauge from the seat to that part? and then fom distribution block to amps
ring is definitely fine, I just happened to have the small block.
I've always read that you want to keep your grounding cable around 3 ft long. You'd probably be ok, but you'd be around 8 feet after routing it.
There is a thread somewhere on here that shows a grommet in the rear that you can go through without drilling and connect... that may be a better option.
i would really love to see some pictures of the pillar ground point because if i do that then the ground wire will be alot shorter please someone i would appreciate it
Well, if thats a C5 corvette you are working on there, the oem ground point is about a foot towards the rear of the vehicle under the seat belt tensioner interior piece, on the pillar.
The interior piece is a little tricky to get off (no tools needed) you just pop the rocker panel cover off, then pop the tensioner piece off (but it slides under the piece above (you will see what I mean) so its a bit of a pain to get off and back on. But definitly doable. Thats where I grabbed the ground for my computer.
i just noticed your trunk picture do you have anymore because i will be going with a similar setup but with the sub facing the trunk thanks
Yep ... still have the setup and love it. I went from having a partition (no sub), partition and sub (center compartment) to this. Used 3 Ed SQ10's to minimize the protrusion in the trunk.
