Sponsored by: Innova
Static/ Feedback noise 08
Old Jun 19, 2008 | 05:35 PM
SpikeZO6's Avatar
SpikeZO6
Default Static/ Feedback noise 08
Have any of you ever experienced static or feedback noise coming from the front door speakers. I notice this ocassionallly when the car has been turned off. I pulled the door panel on the drivers side to make sure I did not have any loose connections but everthing appeared to be ok.
Old Jun 19, 2008 | 10:13 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
i personally have never noticed it but if i recall the radio stays powered up for a while meaning the amps are probally on because that is where the door chimes come from
Old Jun 20, 2008 | 08:45 AM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
I've never heard of this either. Sounds like there might be a problem you'll need a dealer to resolve.
Old Jun 20, 2008 | 09:30 AM
Ozona's Avatar
Ozona
The Bose amp is a total piece of CRAP IMO.
The car switches the amp on to make the doorbell sounds for the DIC, locks, etc. It turns it on, makes it's "beep" and turns it off.
You can hear the low signal to noise ratio of the amp even during the chime event, and it's extra evident with the car off.
There are just a couple of small knits with the 2008 'vette, and that Bose amp is one of them.
To Static/ Feedback noise 08
