I have an AVIC D3 and have a couple of things that arent working correctly.
1) I have single zone climate control. I went to the C5 sticky at the top of the page and the plug shown for where to tap the illumination is not present. I found a similar tan colored wire but that didnt seem to work when I checked it. Any thoughts on how to wire the illumination if you have single zone climate control and does anyone know exactly what wire it is?
2) I hooked my vehicle speed sensor wire up to the green wire with the white stripe in the stock radio harness, went for a drive and got nothing from the speed pulse indicator on the D3. I don't know why this is. I finally found the right wire in this post.
3) also for the reverse signal I read in passing that there is a place you can tap the wire going back to the reverse lights from the passenger footwell. Does anyone know exactly what wire this is.
I'm wondering if I just have to give it a little drive time. It says in the manual to do this but I wanted to see if anyone else had any of the same problems.
2.) I posted a positive result for the green with white from the Bose adapter. Since found it wasn't giving pulses. Just changed the post I made on that, sorry. Just go to the gauge cluster and tap into green with white stripe at position #7. I did an install this morning and it takes a half hour or so to get the VSS from the cluster. Look in vetteessentials.com for the instructions for gauge bezel install and it has clear directions to get the gauge cluster out (You just need to pull it forward enough to get the connector out of it, tap into #7 and put it back.)
I'll pause here for a second to thank vetteessentials .com, forum vendor for the great help along the way on all the installs!
3.) For the reverse wire. Just run the purple wire back to the reverse lights. At the same time place the GPS antenna on top of the 3rd brake light. There is enough room to put the magnetic base and the GPS on top of that with a little glue to be sure it stays there. Run the GPS wire and the reverse wire at the same time toward the front. Not difficult. Just pull the plate and then then pull the panel the license plate goes on for good access back there. Need to drill a small hole in the rear to get the wires through. Lucky we have the plastic cars that GPS type antenna sees through no problem so they can be out of site.
As always, many ways to skin a cat and this is just one!
When I connected the illumination wire the this cream colored wire, I still couldnt get it to work. This is the current problem I'm struggling with. Any thoughts on why this wouldnt be working?
Not for the single zone HVAC, because the cream colored wire in the picture does not exist. The plug for the HVAC is different. There is a similar colored wire on the plug that is there (its tan), but this may or may not be for illumination. If so, it may require the same modification you listed above. Point is we have no idea which wire to even start out with.
You can also remove this wire from the connector and see if the dimmer function on the HVAC readout works.
Then you know you got the right wire.
Just remember to put it back in the right place!
