Sponsored by: Innova
install in houston
Old Jun 21, 2008 | 11:30 PM
mtm87tx's Avatar
mtm87tx
Default install in houston
looking for someone to put my tweeters in a location other then the stock on in my 02Z, anyone have any advice?
Old Jun 22, 2008 | 12:37 AM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
A-pillars in the corners would be the easiest.
what tweeters do you have and what types of mounts do they come with?
Old Jun 22, 2008 | 03:34 PM
mtm87tx's Avatar
mtm87tx
there going to be alpine type x pro series with 1-1/4'' Ring Tweeter im unsure of mounts because they are no delivered yet
Old Jun 22, 2008 | 08:06 PM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Part of me hates you now....mostly because those are the speakers I wanted, i just couldn't wait for them to be available in the U.S. (I'm running the old school SPX 177r)
I'd LOVE to hear them and would be happy to help you throw them in.
Old Jun 22, 2008 | 10:31 PM
mtm87tx's Avatar
mtm87tx
*Edit
i found the pictures of yours RadioFlyer and it looks really good, what all was involved and how long did it take?
Old Jun 22, 2008 | 10:56 PM
Kale's Avatar
Kale
ring tweeters should be close to on axis.
example
Old Jun 22, 2008 | 11:03 PM
mtm87tx's Avatar
mtm87tx
what about in the door handles?
Old Jun 22, 2008 | 11:17 PM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Originally Posted by mtm87tx
*Edit
the original ones (just drill and mount) are a sinch and take about half an hour once the tweeters are wired.
the fiberglass mounted ones I currently have are a little more of a challange. I can set you up for fiberglass but i promised i wouldn't use any more fiberglass in the garage. (makes it smell horrible) If you wanted the fiberglass style, i'll be happy to help prep the area for you, but you'll have to lay the resin, sand apply the SEM coating and paint.
Old Jun 22, 2008 | 11:23 PM
Kale's Avatar
Kale
No.
Old Jun 22, 2008 | 11:28 PM
mtm87tx's Avatar
mtm87tx
ive never done anything like that im not sure how comfortable i am with laying fiber glass for my first time on my pillars, was it hard or just time consuming?
Old Jun 22, 2008 | 11:36 PM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
laying fiberglass is like painting with a brush. Just make sure you have the correct mixture (using a measuring cup) It's mostly a time consuming process. The difficulty is mostly the initial setup (aiming)
- apply a thick first coat
- apply a second possibly a third coat if nessicary.
- Sand down to ~200gr if you're going to use SEM coating. (that's the part with the most labor involved)
- Apply SEM texture coat (second or 3rd coats if nessicary)
- Paint to match interior
Old Jun 23, 2008 | 12:35 AM
BOXOLOGY's Avatar
0BOXOLOGY
Former Vendor
I'll try to post this again as your original post showed you to be looking for an installer that is capable of helping you out in the Houston area:
www.rockstardesigns.net
Rocky has done quite a few A-pillar tweeter installs in C5 vettes.
Hope this helps if decide not to DIY. otherwise, GL.
To install in houston
