Mono is better. Lp or low pass will only have bass coming out two way or full has music and bass which can destroy a sub. Pretty sure I said that right been awhile since I have had to deal with that. I was reading and when I saw jensen I was going to tell you to get a real amp. But that one would be sufficient to power some mid range speakers.
You gonna sell the Jensen? I need a amp to power my mids. I would say a class d mono. You really only need a good 500 watt rms amp. I have had great success with hifonics. Depends on how much sound you are looking for.
Not really an old tale go talk to a audio shop may not destroy but sure is better if just bass is out through. That's why they are called lows. But you can do either I personally just rim low pass
Just to let you know...
Spkrboy is a HIGHLY respected member in the audio section. He has probably forgotten more about audio than most people here have ever known. Just letting you know right up front before you try and argue with him, or say anything that you might later regret...
Anyway...
A speaker (Sub, woofer, mid, or tweeter) has what is known as an impedance curve. The impedance changes with frequency, so you have a 'nominal' number that best represents the 'average' impedance of the driver. (4 ohm load, 8 ohm load, etc...)
For a sub, you can quickly see that the impedance increases with frequency... so any highs being sent to the driver will have little to no impact on it. Asking a sub to reproduce midrange would sound like crap... but I don't see a reason why you can't do it.
The worst that I can think of what would happen is that the driver wouldn't be able to move fast enough due to the driver mass vs. electromotive force being driven into the voice coil. You might end up heating the voice coil a bit, but if your amp and sub are sized properly it shouldn't hurt the sub or the amp.
As for the level of Spkrboy's knowledge base, I suggest you take a look at these threads as an example:
what about a Low Pass Filter in line with the amp, or is a Mono still the best route?
Mono or stereo really doesn't matter except where you're interested in maximizing the output of whatever amps you're looking at. A low-pass active crossover either in-line or built into the amp is a must for good sound.
