Sponsored by: Innova
power window dilema
Old Jul 14, 2008 | 11:18 AM
verne's Avatar
verne
2nd Gear
Default power window dilema
I have a 1976 Stingray with power windows. Drivers side window works, sometimes. When I apply 12 volts directly to window motor contacts, it goes up and down like it should. I connected a voltmeter to the two wires in the plug (from the switch) and I get 12 volts on both wires when I toggle the switch. Seems as thought the switch is fine as well as the motor. Why is the operation intermittant-any suggestions? Thanks in advance.
Old Jul 14, 2008 | 11:39 AM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
Old wiring, it could have worn out insulation somewhere and it's grounding out or the ground itself may be corroded and it's not maintaining voltage. Ugly problems to try to troubleshoot. You may want to pull fresh wires back to the source.
Old Jul 14, 2008 | 12:50 PM
heavymetals's Avatar
heavymetals
Bad ground connection or relay.
I believe if one wire goes "hot" the other wire is supposed to switch to ground through a relay.
That is how the direction is changed.
Old Jul 17, 2008 | 03:18 PM
verne's Avatar
verne
2nd Gear
I'll trace wires to relay and repalce/clean connections or wires to see if that solves the problem Thanks
Old Jul 17, 2008 | 07:30 PM
heavymetals
Hell, could even be the switch.
To power window dilema
