Sponsored by: Innova
backup camera; widescreen.
Old Jul 24, 2008 | 11:03 AM
Mike Mercury's Avatar
Mike Mercury
Default backup camera; widescreen.
I'm looking to upgrade the HU with a unit that has a 16:9 widescreen display. The unit has a backup camera video input.
Should I worry about connecting a widescreen type camera, or just use the typical 4:3 camera?
Any suggestions for inexpensive widescreen cameras ?
Old Jul 24, 2008 | 12:38 PM
heavymetals's Avatar
heavymetals
What matters most is the angle of view (lens angle).
I installed one with a 180 deg lens.
http://cgi.ebay.com/ebaymotors/CCD-L...spagenameZWDVW
On my C5, I modified the housing a little bit and used the screws above the license plate to mount it.
Link to pictures:
http://forums.corvetteforum.com/show...c+n4+in+my+z06
Works bitchin!
Old Jul 24, 2008 | 02:31 PM
rcs128's Avatar
rcs128
I just installed this Boyo camera -- It's really well build, brainless installation and the pic seems fine. Shop around, though, I think I got mine for about $139.
Be careful with the ultra wide angles; they get so "fisheyed" that they become usless when you're backing up close to something. But if you're just wanting to make sure you're not backing up over a garbage can, cat or whatever, you're fine.
http://www.amazon.com/Boyo-VTL300-Li...6924005&sr=8-2
Old Jul 24, 2008 | 06:21 PM
Mike Mercury
thanks guys.
I'm concerned how "cheap bastich" a 4:3 camera image will look as it's displayed on a 16:9 ratio screen.
Is it that big a deal ?
Old Jul 24, 2008 | 08:41 PM
rcs128's Avatar
rcs128
You have to realize that most of those cameras see something like 380 lines of resolution, which is lower quality than regular old NTSC 4:3 television... so the reverse screen image is never going to blow you away with quality.
Old Jul 24, 2008 | 10:32 PM
scott_fx's Avatar
scott_fx
the main difference is that your image is going to be stretched... since you're not going to be recording the image and broadcasting it over the airwaves... you'll be fine :-)
To backup camera; widescreen.
