So i finally had the motivation to work on my car. the behringer was just a pain in the butt to hook up so in my troubleshooting i bypassed it by using a little usb headphone dac/amp and running that into my phaze x-over. totally untuned it sounded pretty decent after i tweaked the gains a bit. i didn't want to drain the battery so i started the car and realized... i will never hear the subtle nuances all this expensive equipment is producing!!!! I tore out the behringer, mounted the old tube x-over and i'm ordering a relatively inexpensive yet decent quality dac and i'm calling it a day. I'll do all the eq'ing on the computer and finally start enjoying the car again.
I don't know, but if you guys have performance mods like cams heads and/or headers/exhaust like i do... i wouldn't waste the money on getting the best equipment.
i just picked up a montero and am contemplating ripping out the seas woofer's in the vette and replacing them with dayton's.
Absolutely, and I'm stock aside from Corsa Titanium exhaust.
The whole car is done in liquid damping, the entire rear in 1-2 layers of raamat, plus ensolite, plus luxury liner. BOTH sides of the rear tub, by the way -where I could get to it - has raamaat.
I just tore out all the ****ty edead from the front of my car and replaced with secondskin damplifier pro.
And the car is still loud. A corvette simply can't be quieted down enough, and the stereo can either only be enjoyed at harmful levels, or with the car turned off, sitting in the driveway.
If I had heard the results before spending hundreds upon hundreds and many, many hours sound deadening... I probably wouldn't have bothered.
Saw your comment in YO-EL's thread regarding "all" SQ going out the window and I flat-out disagree. I can understand to some extent yours and Kales points, but I think you're both taking things to extremes. Extending your logic means it's a waste of time cranking up tunes while you're heading down the road and that's just nonsense.
I just put a full Z06 exhaust setup, including LG Headers, on my C6 vert and it obviously has ratcheted up the exhaust volume (in the "wild" position it's just glorious!) but it doesn't reduce my enjoyment of my audio system one bit.
If it sounds like *** with the motor off it's gonna sound like *** with it on and vice-versa. I will agree with you to the extent that diminishing returns kicks in at a much lower level than it does with home audio, but the real reason YOU can't hear a difference between the Seas and Dayton is because of your experience with the setup and the tuning of your car. Dropping $3000 Utopia Be's in your system? Crazy. Using a $100 Seas midbass instead of a $30 Dayton midbass however is completely in the ear of the beholder. If the Seas sounds a bit smoother, a little more defined to your ear then I don't think it's wasted money at all.
As always, YMMV and what sounds good and is "worth it" to each person varies as well!
I think the point is more that tweaking for the little details, the, i hate the term - atmosphere - is pointless because noise destroys it.
Of course, I think that just buying expensive speakers and throwing them in the doors, tweeters and all, is the biggest car audio waste there is - even more than the detail vs car noise factor.
It becomes even more of a waste when people start switching gear out for "better gear" when its their install that lacks. Imagine if bad stereo install was as blatantly obvious to people as bad performance parts install. It would be like cramming a camshaft into the tailpipe of a car, not getting the results, and changing it out for a different camshaft to cram in the tailpipe...
i probably was over generalizing it. maybe i'll go and edit what i said. but there is something to be said about the point of diminishing returns in a car's environment. If i had to do it again i'd probably have just kept my xtant amp, upgrade the speakers, deaden key parts of the door and focus on installation and tuning. I'm not saying i wouldn't be able to hear the difference, but when i'm driving down the road with the top down, would i really appreciate the difference? I don't know. Again, these impressions were just raw out of the box hook it up and audition. i haven't eq'd anything yet and the x-over points are rough. I'm not saying it won't sound good... but my system would be better suited for a lexas or caddy :-)
yeah, as i stated above, i'm not sayihng it wont sound good... i guess my orig statement is more geared towards not buying the best stuff and working with good quality gear and focusing on the basics.
I suspected that was your line of reasoning and I agree with that completely. Choosing APPROPRIATE equipment is a big part of the equation, and that is a combination of budget, preference and experience. I just felt like I should toss in a reply so that those with less experience don't just see "it's not worth upgrading" even though I knew that wasn't your point.
having a quiet car and a great system is great if you drive a lot. clean audio is less fatiguing and just more enjoyable... if you can appreciate it. :-)
I have slowly gone from all out SQ installs to what I would consider basic (but very good) installs to rolling with stock atm in the 06 2500hd. Diesels make a whole different sound heh. I am sure I will do something eventually, but the crew cab/sub scenario is kind of discouraging atm.
I still love accurate and clean car audio, and always will, but I came to the realization that you can only do so much with a car and its environment that the diminishing returns rear their ugly head sooner than later, especially if you are not showing/competing and actually trying to drive the car while enjoying the music. No amount of deadener and install can fix an unbalanced, very loud, and extremely reflective environment.
I am turning my focus towards home audio stuff, and have a set of keys to a new house waiting for me in 3 weeks. Can't wait to get the new IB sub install rolling. After that a new set of front towers with some Scan Revs are calling my name.
awesome! congrads on the new house!!! and you're going to absolutely love the IB subs! They are the biggest draw at my place right now, largely to the fact that everyone says "they're in there???"
I was wondering about this very topic the other day. I finally collected all my gear for the sound/Carputer install. I decided to have it done by someone that knows more about this than I do. On my way back home, I wondered just how "quite" they could get the Z with a cam and headers and a noisy twin disc clutch. I suspected all along this would be the issue. Oh well, it will sound good and be fast. My home system may sound better, but I can't pull Gs and do over a 100 in my home
I plan on doing a 4 15" IB setup in a manifold in the crawl space beneath the house. It is going to be a bit snug space wise and I might have to move a little dirt to make it happen, but I will get something done in there. The room in question has a small cathedral style ceiling with no real space above it.
I plan on running an EP 2500 to the subs with a behringer 2496 to handle crossover/eq duties to get the sub dialed in. My receiver is pretty flexible with crossovers and eq ability, and I usually let the built in eq program get the system close in the room and then I fine tune it a little bit.
I plan on doing some 7" Scan Revs with the 6600 AirCirc tweet tuned to about 40hz for the new front towers. Basically going to build these from Zaph http://www.zaphaudio.com/ZRT.html
I may end up building the sealed version in a "traditional" sized tower format as I really don't need the towers playing below about 70hz max.
I plan on modding a set of towers that I have currently with a new front baffle and some additional bracing. They have a great piano black finish on them with "decent" drivers in them now and it just so happens to be almost the exact right size for the ZRT I will take a shot at finishing the baffle to match, and if it turns out like crap I will throw a grill on them and call it good heh.
