Sponsored by: Innova
Ipod to amp
Old Aug 5, 2008 | 01:41 PM
John D's Avatar
John D
Default Ipod to amp
Can I connect an Ipod directly to an after market amp with RCA plugs? will it work? I'm currently installing speakers on my 68 Firebird and don't want to install a head unit,
Old Aug 5, 2008 | 01:56 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
yeah it will work not ideal but it will work
Old Aug 5, 2008 | 02:22 PM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
It'll work, but the more you turn up the headphone amp on the iPod the more noise you'll introduce. If you got an iPod cable that connected to the dock and output it's pre-amp signal you could use something like this:
http://www.darvex.com/miva/merchant....roduct_Count=1
It would give you gain control, essentially becoming a passive pre-amp, only one without switching.
Old Aug 5, 2008 | 02:29 PM
John D's Avatar
John D
Komoman. This seems close to what I think I need. I can connect the Ipod to the rca controller then to the amp? not sure...
Old Aug 5, 2008 | 02:44 PM
scott_fx's Avatar
scott_fx
id go dock out then to a preamp or attenuator then go to the amps. it should be pretty decent. you could go with something like this:
http://cgi.ebay.com/SOUNDSTREAM-MTUB...QQcmdZViewItem
and this:
http://cgi.ebay.com/NEW-CABLES-35507...QQcmdZViewItem
should give you decent sound and a little more control
you could replace that cable with this:
http://cgi.ebay.com/NAVIPLAY-BLUETOO...QQcmdZViewItem
and this:
http://cgi.ebay.com/Motorola-DC800-B...QQcmdZViewItem
and have it wireless. the trick is that you'd have to find an appropriate plug for the car, shouldn't be hard, they have them at radioshack
Old Aug 5, 2008 | 03:22 PM
pentavolvo's Avatar
pentavolvo
and
http://cgi.ebay.com/iPOD-Dock-to-RCA...2em118Q2el1247
is how i would do it, get the lineout from the ipod and charging capabilities then use the **** as a volume control
Old Aug 5, 2008 | 03:36 PM
scott_fx's Avatar
scott_fx
ooo, i like that charger. i would go with that, but i still like the pre-amp :-)
Old Aug 5, 2008 | 04:10 PM
pentavolvo's Avatar
pentavolvo
scott i know u love that preamp lol, but honestly if hes not aiming for crazy SQ i feel he could get away without it. Last summer when I pulled the alpine headunit from my boat to put in one of the cars i was selling, i did the ipod straight to the amp with the same stuff I have linked and I had to up the gain a bit on the amp to get full volume but honestly SQ vs with the headunit was the same
Old Aug 5, 2008 | 04:34 PM
scott_fx's Avatar
scott_fx
i doubt that preamp will give him that much of an improvement in sq, just more adjustments and in all honesty.. it looks cleaner then that volume **** :-)
Old Aug 5, 2008 | 05:44 PM
pentavolvo's Avatar
pentavolvo
agreed, being a 68 firebird maybe he is leaving the OEM deck in dash and hiding the ****
Old Aug 5, 2008 | 06:24 PM
scott_fx's Avatar
scott_fx
ha.. i only read half of the op's post. well, he has options now. :-) hell... just going from the headphone out to the amp may be good enough for him then.
Old Aug 6, 2008 | 07:33 AM
John D's Avatar
John D
Thanks everyone for the help. I'm going with the RCA controller and docking cable for now and see how that works. Last night I plugged the ipod directly to the powered sub, the car whole car was rattling from the bass. I'm picking up an amp and 6X9 speakers this weekend, once eveything is installed I'll post my results.
Old Aug 6, 2008 | 07:52 AM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
Make sure the amp you choose has a crossover and sub/pre out to pass the signal to the powered sub. Set the crossover to Low Pass (LP) at 80Hz to start with and adjust up or down as your ear dictates. Enjoy!
To Ipod to amp
