Needed Specs on 2008 door speaker Ohms
I must admit I am not a audio noob, but I am always willing to learn from others, specifically when I have not done a install on a C6 and it is all new to me. My interest is in any experiences in your installs.
I am trying to "cheat" a little bit and leave the door woofers in place, but since purchasing my c6 this past Friday and spending a week with it and comparing it to the system in my 2007 Avalanche, there is no comparison. I still may may try it, but I am prepared to do a full install.
I am lucky in that I have a lot of left over equipment. Including Alpine headunit, signal processor (PXA-701), Boston Acoustic Z series component speakers, Diamond Audio 7056 (5 channel amp), 2 Audison amps, 1 Rockford fosgate amp, and plenty of sub options.
Keep any advice coming as it is helpful as I move forward.
Can you send me the model numbers for the Seas speakers you mention.
as for the seas speakers, i'm not 100% on the 8" version but i have the 7" g18rnx/p, but they are hard to come by right now. there are some variants with slightly different characteristics but if you go with the rnx/p line (for instance the CA18RNX) you'll be getting a good bang for the buck.
here are some other 7" driver reviews:
http://www.zaphaudio.com/6.5test/
the tweeter that spkrboy praises is the Vifa D26NC5 which is pretty cheap at under $30 ea
http://www.zaphaudio.com/tweetermishmash/
if you do a search for spkrboy he has a great thread about installing those drivers into komo's c6
Still plan on using My new Diamond Audio D7 Amp and Boston Acoustics Z-series components (6.5) for my C6 install. I'll save the other equipment for my 1970 Karmann Ghia project.
